Results 1 to 8 of 8
Thread: vibration when in gear vs series 3 ute
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    Default vibration when in gear vs series 3 ute
    Hi all
    Got a vibration problem when i put my ute in drive , only at a standstill when i first start
    the motor it runs smooth but when i shift into drive it runs rough , and when you start moving
    it runs smooth as well . I have given it a full birthday new oil and filters through out , new high
    tension leads , plugs the lot , What do you think ?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    Hi
    Just finished changing both engine mounts,Took 2 1/2 hrs you would,nt want to do it every day i know that, but best of all my problem is solved. I did not take the a/c motor of
    because it made no difference.Just jack motor up so you can get a ring spanner on the under side and get it that way.Yeah both mounts were all split.
    Cheers Dude.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Muzz the kiwi View Post
    Hi
    Cheers Dude.
    Glad you got it fixed. It can be a pain of a job, especially the first time you do it.
    MY RIDE
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    VS Ute
    May 2010
    Sounds like the same problem as mine.
    Will have to check my engine mounts out
    Where did you buy your new ones from and how much did they cost?
    VS SERIES 3 UTE
    May 2010
    Gold Coast
    HI
    I got them from supercheap at $57 each . Jack up your engine with block of wood between your sump and
    the jack and get under your car with a light and check out your mounts, mine were all split . Now it runs
    smooth as silk . Good luck .
  1. Mad Vibration when 5.0 is held in gear.
    By Deneo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2010, 06:02 PM
  2. VU series 11 making a thumping vibration
    By loyalea in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2009, 01:08 PM
  3. New Top Gear UK Series
    By BullittSV6 in forum The Pub
    Last Post: 07-02-2009, 02:31 AM
  4. Gear stick vibration vu 5.7 ute
    By afterburn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2008, 04:49 PM
  5. enter to 1st gear vibration
    By donjulio in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2006, 01:39 AM
