Results 1 to 16 of 16
Thread: VS Commodore, Front Left tyre Rubbing on Strut
    5 speed VS
    Jan 2010
    Default VS Commodore, Front Left tyre Rubbing on Strut
    Hey all just wondering what yu all think would be the problem with my car,
    The problem is My Front Left tyre when i turn right Scrubs on my Strut Turning left going straight it is fine only time the problem occurs is when im Turning Right :S:S:S
    Anyone have any ideas of what the problem could be ??
    Thanks Again
    vs 5L ute and vh project
    Evel Cownievel Champion!
    Dec 2008
    NSW inverell
    5 speed VS
    Jan 2010
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    couple things, bent strut, worn camber (hub to strut) bolts, wheel berings loose
    any abnormal movement in the wheel/steering ?
    vr acclaim wagon, vs wagon (project) & vx belina
    Apr 2010
    brisvegas
    5 speed VS
    Jan 2010
    Na no abnormal movement at all,
    But the wheel bearing on the right side sqeeks rofl. so i know it needs to be replaces anyone suggest what my next step shoudl be
    moff_man's Avatar
    Nov 2008
    5 speed VS
    Jan 2010
    Went today to get a front end alignment they told me they could only do the Toe cause it was scrubbin on the Strut..
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by vs5speed View Post
    Did you ask them whats causing this to happen? It sounds like theres some very worn out parts on there that need replacing..Its probably dangerous.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The adjuster on the strut could be wound all the way out causing the top of the wheel to be too close to the strut. When turning left the wheel angles in more and if the alignment is out, the scrub radius could be forcing the wheel over more, causing it to rub.
    Visit my Facebook page
    vz ss and vs statesman
    Mar 2009
    Id be checking that the stub axle isnt bent or the strut. Did you buy the struts new?
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    Quote Originally Posted by trav_304 View Post
    they dont have a stub axle its a bolt on hub
    5 speed VS
    Jan 2010
    96vs calais
    Sep 2009
    hey mate i had this same problem on my vs and just wound in the camber adjustment screw on both sides a couple turns and it was sweet after that
  15. #15
    5 speed VS
    Jan 2010
    hey sorry about extremely late reply but ive tried that its still scrubbing but only when i turn left?
  16. #16
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Tire rod ends or ball joints aren't stuffed?
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  1. Front Passengers door rubbing on front guard - how to fix?
    By FlyingVXIIKiwi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2010, 11:34 PM
  2. Rear Left Tyre worn evenly to 40% while others are 80% with only 20000 km on the care
    By houdini_007 in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-07-2009, 11:37 AM
  3. Tyres: Wearing inside edge on left back tyre, IRS.
    By Brian MacArthur in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2009, 12:35 PM
  4. will 19" fit to VX with no tyre rubbing
    By s/cvxact in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2008, 08:52 PM
  5. tyre rubbing
    By LOW VX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2006, 09:06 PM
