Results 1 to 16 of 16
Thread: can't get reconditioned engine V6!
    VSII Ute
    Feb 2010
    WA
    Exclamation can't get reconditioned engine V6!
    I took my automobile to local workshop, and their diagnosis was the engine is full of sludge,
    not just the sump, but the galleries as well. They said the Ecotec would need replacing
    sooner or later. But the surprising bit was their claim that one can't get a reconditioned
    engine right now (in a city of more than a million people). Their recommendation was a
    second-hand engine what would cost $3800 fitted. I remember seeing an ad somewhere
    for reconditioned Commodore V6 $1995, but don't recall if that was the older donk.
    I find it hard to believe that nobody has a VS V6 - it is hardly rare.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    I have seen good second hand V6 motor sell for $300 to $600 private sale. Then add another couple of hundred for fitting.
    This place in SA sells 5.0 V8 conversion kits for $2200 plus fitting - JUST COMMODORE SPARES :: Wheels
    Shop around to get a better price.
    Does the workshop have big windows ?? They may have seen you coming
    http://woteva.tk/
    If it ain't broke... I can break it for you
    VS Commodore S
    Aug 2009
    Holden sells AC Delco Reco engines not sure about the cost though ... they are exchange though
    tivoom's Avatar
    tivoom is offline pimpin pizza wagon
    VR S2 Wagon
    Jan 2009
    newcastle
    wow thats a joke mate it would cost less to pay some one to rebuiled the one you have with a few go bits put in for good times lol
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    go somewhere else, your mechanic is ripping you off, im a mechanic and im not in the bussness of ripping people off.
    RUN THE BLOODY ENGINE ON DIESEL ENGINE OIL, that will clean it out, also if you are too scaired of the diesel oil run the nurlon cleaner stuff through it, problem solved. may take awhile for it to come clean but its better than saying you need a new engine because its gumed up. thats just crap.
    im running my vr 6 on diesel oil now and i cant notice any diffrence in engine noise. its getting verry clean tho
    VR Commodore S 5-speed
    Mar 2010
    Wilton, nsw
    Quote Originally Posted by moff_man View Post
    I totally agree with that statement aswell,
    im a mechanic myself and i know of a fair few people in my area that do these sort of prices for jobs like an engine.
    i bourght a new motor for my VR, it was $660 (very low k's, and they proved it) and it took me a weekend to do the change over.
    its pretty simple, i cant see the value in a quote like that.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    running diesel oil cleans it??:S what if i mix diesel fuel in for a little while before an oil change?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VSII Ute
    Feb 2010
    WA
    Followup to various replies:
    This dealer does have big windows, and also has a brass plaque on the wall saying the building was opened by the state premier, so I guess they are suspect.
    I tried cleaning the engine, drained while hot: then filling with kerosene, then draining - it came out black.Then changed oil filter, then run 15 minutes
    on home-brand oil with a bottle of "oil flush" additive, drained it, this time it was clean. Change filter again and add proper grade oil, but oil
    pressure is still low.
    Anyway, I found some wreckers offering cheap engine swaps, but they weren't so new - like 150-160 thouand km. One of them said you can't use a VT motor
    in a VS - there are some minor differences. But the dealer reckoned VT engine was same. Who is right? What about the VS utes that were made
    after the VT sedan came out?
    vs commodore
    Oct 2009
    Tamworth NSW
    I have a reconditioned engine in my VS from Redlands engines in Brisbane ,and I went to buy a water pump, and the local holden dealer needed my engine number because apparently after a certain build,the VS water pump was changed somehow.I went out and got the engine number and gave it to him and he looked at his computer for a bit, then said the engine was a VX engine.It used the later type water pump.I asked him if he was sure and he said he was,the engine number confirmed it he reckoned.I told him it was a reconditioned engine and he said yeah,they are all pretty much the same.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by jeepster View Post
    A 15 min engine flush is not going to clean it out properly....
    sounds like the oil pump could be blocked or not working best would be to remove the sump and give everything there a clean.
    My VR needs a oil change more often due to it not been serviced by the original owner as a result it is full of crap.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I read somewhere that if you drain the oil out and put 4 litres of auto trans fluid in and run it for a while it will clean the crap outa the motor.
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Quote Originally Posted by Dayvo View Post
    that's something i think you would want to try on a scrap motor first
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Why waste trans fluid. Use kero or deisel or something. Not to mention if you use trans fluid, you're gonna have to flush it with a solvent to get it out before you put coolant in it.
    1999 v6 vt commodore sedan
    May 2010
    Quote Originally Posted by maldotcom2 View Post
    ummmmmm you dont put coolant in the engine...
    and vnv6 putting diesel with your petrol is not the best idea if your looking to clean out your injenction system, use injector cleaner, plus your car will run like shit
    i have mates that run diesel oil on older engines every second change for the full 10,000 ks and then back to petrol oil. definatly cleans it out anyway.
  15. #15
    moff_man's Avatar
    Nov 2008
    15w40 diesel oil would be fine to run in it for 5000-10000km dump it out and run what ever oil you want after, even run the diesel oil for 1mth if you like but 10-15min is way to quick. my cars get oil changes every 5000km or 3mths depending what ive done with the car (trip or town). if you are having oil pressure issues than the engine could be catus, and has been left too long.
    looking on ebay most seccond hand engines are around $650 buy it now
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
  16. #16
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
  1. Reconditioned Engine
    By Ebatra in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2010, 11:31 AM
  2. [NSW] WTB Reconditioned VR V6 Transmission
    By whitevrboi in forum Swap / Wanted to Buy / Trade
    Last Post: 28-04-2010, 07:34 PM
  3. FS VR with reconditioned V6
    By jd67 in forum Vehicles For Sale
    Last Post: 15-04-2008, 09:12 PM
  4. V6 VS II - low price reconditioned engine supplier?
    By trozza79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2007, 01:56 PM
  5. reconditioned motor
    By =Calais v8= in forum General
    Last Post: 10-01-2007, 03:10 PM
