Results 1 to 5 of 5
Thread: wouldent start
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Default wouldent start
    i went to try and start my car down the street and when i clicked it over it sounded like the starter was trying but then it just conked out and then i tryed again but all i could hear was the relay clicking over so i waited 5 min and tryed again it took a few second but it started. i am think i need a new starter
    VS-II Esteem
    Apr 2010
    Tasmania
    It's very likely that. I'd probably check your battery too, and if the battery's gone then check or replace the alternator. Chances are though, it's just the startermotor on its way out!.
    Cheers!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As above - I'd check the battery first - if it's much more than 2 years old it will be on borrowed time, however if it's still pretty new then check the volts with a multimeter with the engine running at about 1000 rpm....if it's reading about 14.3vDC the alternator is OK but if it's reading under 13vDC I'd suspect the alternator.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    i got a mech to come have a look at it but it started for him first try and it cant be the alternator cause i only replaced it last week but he said it sounded like the starter was on its last legs so and i am also getting my oil presser tested so that's like killing two birds with one stone
    VX II Calais LS1
    Jan 2010
    check the power cable that goes direct from the battery to the starter, it may have a bad connection/dirty terminals etc
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
  1. Wouldn't start when warm, now won't start at all
    By karwalski in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2010, 06:18 PM
  2. car won't start
    By 94calais in forum V6 Development And Modification
    Last Post: 04-04-2008, 05:28 PM
  3. VP won't start
    By fullymetal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 04:13 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
