On the manual gearbox there are two connectors, one for the reverse lights and the other for the speed sensor.
Reverse switch
Connected to the auto shifter is a white plug with four wires connected to it the grey and grey/black wires are for the neutral safety switch, they need to be shorted together to allow the car to start. The other two wires on this connector are pink and green, these wires are for the reverse lights and need to be run to the T5 Reverse Switch.
[B]Speed Sensor[/B
Now on the speed sensor to get this working you will need three things:
The signal wire is the Purple/White cable this has to be extended over to just above the ECU where you will also find a purple/white wire on a plug leading from the computer up into the dash, this is the wire you need to cut and connect your extended wire.Only cut this wire on the body harness side leave the ECU side, and join the new purple and white wire to the purple and white wire that leads to the dash/speedo.
- Positive
- Negative
- Signal wire to the dash
To avoid Engine light issues you will also need to solder in another wire to this purple and white signal wire which is to lead into D2 on the Manual ECU
The second wire on the speed sensor is Pink/Blue this wire is your positive. This wire should be run through a fuse into a power output, ie. stereo, key on power.
The third wire is your negative, this is the black/white wire and it needs to be earthed out onto the body somewhere.
what model car u get ur gearbox from im plannnin on the same conversion...within couple weeks
VS Commodore
That appears to be a comprehensive solution for those doing the swap - good one.
i take it this was with the manuel ecu is is it still able with the auto ecu?
Yes definately will get best results with manual ECU.
would this work with a v8 conversion too?
i not to sure but. I could be wrong and hopefully someone can correct me if i am but i don't believe there would be.
hey mate just wondering which ones d2 on my computer an plug r marks a- b but not c-d e-f look in computer were plugs plug in and found c a e just above the pins so im guessing that below c is d but it not mark so i dont wanna make the mistake an wire it in an be wrong. if u had a picture of ur ecu with d2 pointed out that be helpfull thanks
alll sorted mate thanks for the guide cars running like a dream
this works for the t5?
Thanks for the info on this.
Can I just plug the manual computer into the auto loom now ?
Cheers Nick
hey mate. if u used a manual computer for a t5 conversion can u please tell me the service number on it?
would this stop stalling issues as well? i just got a manual loom and am going to put it in.... b4 i do just thought id ask.
opps wont do that again
hey mate when i did it i used the auto loom an did as stated if u make sure u hook the d2 to ur computer in ur car wont stall. i had the speedo power hooked up to cig light but fuse was blown which made engine light pop up an stall new fuse an she now runs like a dream. running manuel ecu.
hey mate, what difference does it make from the ecu side and the other side? i've cut from the ecu side and my speedo works fine but i get the engine light come on and stalling issues on deceleration
also if i leave the wire connected to the purple and white that runs to the ecu my speedo doesnt work at all...
please help.
cheers
Nick
has anyone had isues with the starter motor hitting the flywheel or not engaging, i got a delco remy starter off a manual vn series 1, but its looks to be about 1mm to close to the fly wheel thus not alowing the gear to engange. should i try another starter or have i been given the wrong one. i tryed to move it a around but you cant shift it at all.
just about to finish auto to manual conversion.
almost every part this guy has given me has been wrong so farexcept the gearbox it self
anyidears?
the end pink plug ( theres PINK PLUG. PINK PLUG. BLUE PLUG.) so the outer Pink plug has the violet/white wire at C5. You ned to remove the plastic locking clip before you can see it.in very small writing it will show the numbering order 1 to 16. cont across 5 pin positions from the 1 side and it will have the violet/white wire which is the Auto speedo pulse signal out. the other row of the same plug is the D side and also shows the numbering 1 to 16. It will have D written on it too at the edge of the plug. Again you have to remove the pin locking clip to see it easier. The D2 position is blank.
I had the same problem with the gearbox and starter from a VN,. When I pulled the starter motor out there was an L shaped bracket on top of it it is about 2 or 3mm thick and about 1cm wide when I put that bracket on problem solved, a couple of washers about 2mm thick would do the trick.
I have just done this conversion and I sent my ecu to a guy on the gold coast, he remapped my ecu to manual and all I had to was connect the blue/white wire to the purple wire on the speed sensor and hook the reverse lights up as above and bingo no engine light and speedo works a treat. Cost me about $90 from memory.
I'm using a VS Manual Computer and an auto wiring loom, i'm just wondering what people do with C2, C3, and C13 wires on the computer?
Earth them, dont use them? or other?
Any help greatly appreciated
