Results 1 to 4 of 4
Thread: VS - Replaced Bulb, AC Fan not working
    1996 VS Commodore Executive Wagon
    May 2010
    Default VS - Replaced Bulb, AC Fan not working
    Okay, long story short, just bought a VS commodore wagon, I went to replace a bulb on the AC control which was blown, the bulb holder had pushed into the AC control unit.
    I Looked up some instruction and removed the control unit from the dash (removed the heater control rod etc). When I put it all back together, I tried the AC but it was making a sucking sound (yep, the vacuum hoses at the back).
    So I pulled it out again to give it another go, suddenly the fan control won't work. Won't work on 1,2,3 or 4.
    Help? I'm a total noob at this stuff. If no one can offer me advice on how to fix it, can you recommend who I should take it to? Auto Electrician? Mechanic?
    VS Clubsport
    Nov 2008
    Auckland
    Don't panic bro, have you checked the simple stuff like the fuse? Was the fan working before you pulled the control unit apart? And are you sure that you reconnected the electrical fittings properly?
    May 2010
    Okay, fan is working again.. must've been a loose connection, I finally got the stupid FKN temp thing right.. what is with that piece of crap gear and rod.. omg.. lol
    Anyway, the only thing thats not right now is I can't select where the air goes.. it's stuck on front window.. any idea? I've checked and double checked the vacuum tubes..
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Note, you can only change the blowing position with the engine running.
  1. trip meter not working replaced cog
    By Vp Commodore 001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2010, 10:45 PM
  2. Replaced PCM... Now tacho and speedo aren't working?
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-10-2009, 10:15 AM
  3. temp gauge not working after belt replaced
    By bigbikes in forum General
    Last Post: 03-09-2009, 09:39 PM
  4. AC switch bulb
    By tt460 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2009, 01:22 PM
  5. bulb holders
    By ad45 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-01-2007, 08:34 PM
