Results 1 to 3 of 3
Thread: Level 3 dash speedo not working after upgrade
    VR V6 UTE
    Mar 2010
    Default Level 3 dash speedo not working after upgrade
    OK, after changing my dash over to a level 3, my speedo isnt working
    I took it around the block and nothing, not even the digital one works on the dash.
    As this was converted from auto to manual, would it be the purple white wire not connected properly
    somewhere? I have checked it where I joined the wires when patching it into the loom and all is OK there, everything else works on it, except the distance till empty doesn't seem to give a correct reading, everytime I reconnect the battery it changes different readings, from 190 to 140km.
    Any help much appreciated.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If you put the original cluster in - does the speedo still work?
    Inspect the back of the cluster - the tracks can fail.
    and 3 Dangerous non ABS VN's
    VR V6 UTE
    Mar 2010
    Will check that out, I have a level 2 dash here will check it out with that one as im not even sure if the original one worked.
  1. Will a level 3 dash be able to work on a level 1 loom?
    By dk4400 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2010, 09:18 PM
  2. Done level 3 dash upgrade but a small problem
    By bazzii1388 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2008, 04:26 PM
  3. Level 3 Dash installed how to get A/C w/o climate control upgrade?
    By ThongyVL in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2008, 12:59 AM
  4. VS Speedo not working (level 2), can anyone advise?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2007, 06:35 PM
  5. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
