Results 1 to 9 of 9
Thread: VR Commodore ignition barrel replacement - cost ???
    VR Commodore
    May 2010
    Angry VR Commodore ignition barrel replacement - cost ???
    Holden dealer quoted $600 for replace ingition barrel and housing - anyone else think this is a bit rich!!!!!
    Anyone know of a machanic in Newcastle / Lake Macquarie who could do job for better price?
    VR Acclaim
    Sep 2008
    Kingsley WA
    I had an ignition barrel replaced for $129 in 2006, including labour. I have it recorded as $54 + $75 so I guess the part cost $54. There is no mention of the housing.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    housing is around $150, if you are having problems with the steering lock try a search on this forum you might be able to do it your self, coding the new barrell is relitivey easy, i do them at work.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by moff_man View Post
    How is a new barrel actually coded?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Coding is the number assigned to each 'bit' of the barrel assembly. The number on each represents the position of the slot in the 'bit'. When the key is inserted the highs and lows on the key blade match the position in the slots so all the 'bits' neither protrude nor recede in the barrel. This allows the barrel to rotate in the housing with the key when its rotated. When you pull apart the old barrel, all you need do is record the number on each 'bit' and its correct position in the barrel. From memory there are 10, 5 on each side. The new uncoded lock comes with a bag of assorted 'bits' allowing the lock to be coded for any combination.
    I think I paid around $60-70 for an uncoded barrel (no housing). This is all thats required to fix the busted shaft that operates the ignition switch.
    vs commodore
    Oct 2009
    Tamworth NSW
    Holden want $600 to supply and fit the barrel and just do that.What a joke,no way Id pay that.Go and get the parts yourself and fix it yourself, and save a heap of cash in the process.
    moff_man's Avatar
    Nov 2008
    each dealer have there own pricing (dont blame HOLDEN) blame the dealer (please dont mention names for leagel reasions possibly) i know where i work i can get prices on things done at half the price as thoes at city dealers.
    to suppily and fit plus code a barrell should only cost x for parts and 1hr labour max than if the housing is stuffed thats extra but 600 bucks is too much
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    I need to change the barrell,key reader and ignition switch on mine. Adds up to about $130 (ish) in parts at retail and I think it's usually about an hours labour.
    Why are you changing the barrell? We usually only do the housing if the barrell is jammed and it's almost impossible to remove it from the housing. If the end of the barrell just broke off in the ignition switch then it should be a reasonably straightforward job.
    You could always try a mobile locksmith for a quote.
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    vs executive s2
    May 2010
    tThe local locksmith mate $150-250 should be the going rate.
LinkBacks (?)
  1. 12-07-2010, 12:16 AM
  1. VT ignition barrel replacement
    By Chosen1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2011, 08:02 PM
  2. VT Commodore - Broken Ignition Barrel
    By demps2009 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2010, 07:16 PM
  3. Ignition barrel jams solid VT Commodore 1999
    By Gazzara_0306 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-03-2010, 08:34 PM
  4. How to remove ignition barrel VN commodore
    By Trevornicole in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2005, 05:14 PM
  5. VK ignition barrel replacement
    By tzeck in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2004, 04:19 PM
