Results 1 to 9 of 9
Thread: Last Resort Until $$
    VT S2 Club Kitted, VR SS, VL Executive
    Oct 2005
    Broken Hill
    Default Last Resort Until $$
    Ok went to service my gear box today in my ss (auto), and i looked under the car and the servo casing has a massive split in it, and is spewing oil.
    Now was thinkin after a few beers, that product "need-it" if i was to paste that over the case and piston cover would it hold until i get some $$ for a t5 box. Or am i wasting my time.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i think there is a liquid steel type product called 'devcon' or something that a few bike riding mates of mine have used to bodge up cracked engine cases etc. i spose if u clean the area real good first before u apply the knead-it/devcon its worth a shot at least. it might hold up fine but i dunno if i would do any road trips with it
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VS Calais
    Mar 2010
    You would need Knead-it steel. also make sure you clean all fo the oil off with a solvent or it will leak or fall off.
    Knead-it steel
    Quote Originally Posted by destiny View Post
    wtf? im not stupid, theres no such thing as a tyre valve
    vr
    Jun 2009
    defintley use the devcon. its called devcon-f, and should get you out of trouble till for a short time till you can get some $$. make sure the area is 100% clean of oil.
    Quote Originally Posted by v6monstar View Post
    dude your piston slapping your going to have to titan up your pistons be for you throw a con rod throw the side of the of your engine
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    ive used it before on a landcruiser box, the filler bolt snaped half off and i used a simmilar product to fill the gap with the plug in place, today you cant even notice it
    Oct 2005
    Broken Hill
    Just a quick question, would a Getrag V8 304 gearbox out of a vt ss bolt up to mine or i have no hope?
    moff_man's Avatar
    Nov 2008
    yes if its the same engine, one from a gen 3 (6 speed) will not with out modification but if its a 5.0L it will, get the whole setup tho (flywheel and clutch)
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    vs clubsport
    Mar 2009
    brisbane
    it wont work as there is pressure in the servo housing you would be lucky to make it out of your driveway with out it leaking again
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    Oct 2005
    Broken Hill
    Ok put it on went for a lap and the car wont stop spinning haha, must of been loosing so much pressure. Hopefully it will hold until i can get ahold of a t5 or getrag
  1. Vn 5 Speed issues - Last Resort Post... HELP!
    By m3taL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2008, 10:51 PM
