Results 1 to 10 of 10
Thread: water noise from dash
    VZ SV6 AND VL CALAIS TURBO
    Jan 2010
    brisbane
    Angry water noise from dash
    hey just need to know how to stop the fish tank noise coming from the dash i know it got something to do with the heat lines but have no clue if anyone knows please let me know it shitting me off
    MR HAVICK
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Jan 2010
    brisbane
    how do you do that i know it the tap and a coke bottle but do you bleed the heater hose as well
    MR HAVICK
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Did you turn on the heater when you bleed the system?
    moff_man's Avatar
    Nov 2008
    ok coudnt find a how to so ill wright one up quickley.
    to just bleed the system on a VS vr simmilar
    turn the heater to max hot
    take the engine cover off with the 4x 10mm head nuts in each corner of the cover
    get a coke bottle or old radator hose, or anything to get the level up high enough
    open the bleed nipple on the top radator hose thurmo stat housing with a big flat blade screwdriver. not nessesry to remove all the way as it has a slit cut in the bolt.caution, dong it back up super tight can cause it to crack sometimes
    fill the coke bottle with coolent or distilled/clean drinking water
    wait till the streem comming from the bleed nipple is steady and no air is comming out.
    tighten nipple
    start the car and allow to idle with the coke bottle or simmalar still in place and allow to get warm.
    shut down the engine and repeat bleeding till all air is out.
    remove coke bottle, top up radator, replace cap.
    test drive till engine at normal opreating temp.
    check level in overflow bottle daily untill level stays at right level
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    VS Berlina
    Jul 2009
    Melbourne, VIC
    Quote Originally Posted by moff_man View Post
    tighten nipple
    On this note, if you were to have this problem of a cooling system in need of bleeding (I certainly do) would that be cause for the coolant level to decrease constantly?
    moff_man's Avatar
    Nov 2008
    big air pockets can cause this, but most likley to be a loss of coolent somewhere!
    VS Berlina
    Jul 2009
    Melbourne, VIC
    As there is no obvious leak (no water on ground etc), this would confine any leak to something in the range of expensive for fixing I would think.
    Damn.
    moff_man's Avatar
    Nov 2008
    inlet manifold gaskets are common, if your are handy with tools its pritty simple to do too.
    other wise a pressure check is a good start to confirm any hidden leaks.
    i just replaced my radator i noticed a leak awhile ago but coolent level was ok, few days later no more leak but level droped, i also did a 300km trip (check before leaving was ok) the drivers side tank was split - 2nd commodore to do this of mine
    VS Berlina
    Jul 2009
    Melbourne, VIC
    Cool thanks I will get onto pressure checking it before anything else
  1. water noise
    By dman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2009, 11:15 PM
  2. water noise behind dash
    By Force88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2009, 09:42 PM
  3. water noise behind dash?
    By GH05T in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2008, 10:44 PM
  4. Water noise from dash, i think!
    By dazza33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2008, 09:32 AM
  5. water noise when starting
    By BobEddie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 11:18 AM
