Results 1 to 12 of 12
Thread: VR-VS V6 Starter Motors
    1994 VR Wagon and 1997 VS Calais International
    Jan 2007
    Default VR-VS V6 Starter Motors
    Can anyone confirm if a Bosch V6 Starter out of an Auto VS will fit an Auto V6 VR
    I have read other posts and there seems a to be a lot of conflicting answers
    Stop looking for the Potholes and sit back and Enjoy the Ride
    Jan 2007
    bump bump bump
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    90% of the Commodore starter motor adverts on Ebay, and there are dozens of them, say they fit any Buick/Ecotec motor except early ones so I'd say yes.
    I also see it only costs $110 for a brand new reduction gear starter on Ebay.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    some times depending on year model will ither have 2 long bolts or one long and one shortish. just be sure if you are swaping starters you check the bolts
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    Jan 2007
    Quote Originally Posted by hako View Post
    Apparently the cheap china ones dont work properly
    Jan 2007
    can you have a look at yours and let me know what bolts you have
    moff_man's Avatar
    Nov 2008
    i have 2 bolts the same length
    Jan 2007
    Gee i thought there would be more replies to this topic
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Sara Pax View Post
    That's probably because you asked for someone to confirm a question that only someone with considerable knowledge of Commodore starters would know. I'm not one of those people so I just used Ebay to tell me. The cheap Chinese starters have a 12mths guarantee and the sellers have good feedback.....not a lot of wreckers give 12mths guarantee!
    2004 holden VZ v6 ute.
    Feb 2011
    Bathurst
    i think my starter is on its way out. When its begins to crank over and starts to fire a chirping grinding noise comes from the left side of engine, very loud also, Replaced water pump but was not the problem. We think its not disengaging For 3 to 6 seconds while the engine starts to run. Once engine is running no sounds or problems, Just did the oil, filters and new coolant.
    Did water pump as it was making a little noise every rotation, all fixed with the new one.
    Also Is it ok to replace yourself if that is the problem?
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Quote Originally Posted by sirjolly18 View Post
    sirjolly, it certainaly is OK to replace yourself. The auto electrician I bought my starter motor from told me the 6 cyl auto has a different type to the manual. Look here Changing VS Starter Motor and here VS starter motor advice needed
    Hope this helps.
    Jahwah is offline Jamie91
    VR Executive
    Nov 2010
    I have a vr auto starter motor only 4 monthes old for sale. And a few reco alternators if your after a new one?
  1. are vr and vs starter motors the same
    By peckzz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2009, 03:49 PM
  2. starter motors!!!!!
    By vh2nv in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-03-2009, 09:40 PM
  3. vn starter motors
    By HÝPÕ-5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2007, 06:44 PM
  4. starter motors
    By jatsvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-02-2007, 08:53 AM
  5. vl 6 cyl starter motors
    By mems84 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-11-2004, 04:24 PM
