Results 1 to 5 of 5
Thread: 93 vr berlina problems maybe?
    vr berlina
    May 2010
    Default 93 vr berlina problems maybe?
    gday I bought a 93 v6 berlina auto cheap as it had a stuffed gearbox so I then bought a 95 vr minus a motor from a workmate and swapped the boxes.The car ran well and the gearbox worked well except the engine warning lamp came on after a km or 2.So I checked the fault codes andnit was the gearbox which I put in to get fixed.They replaced the solenoids or whatever and said it was better but they noticed some material in the oil and the warning lamp returns at around 80kph and the gearbox would need a rebuild or get another one, it may last 6 months maybe.Anyway so I thought maybe the ecu was spiked or damaged when the othher gearbox stuffed up so I swapped the ecus and took it for a drive and took it up to 100kph and sat on that for around 60km and no warning light came on and it ran fine.Then I noticed that the distance to empty display was erratic and would go from 220km to 30km and so on and as the fuel gauge isnt working at the moment I swapped the ecus back again both ecus are labelled 3.8l auto.And the warning lamp reappeared at 80kph again no change in the performance of the car I still drove at 100kph for around 30km and nothing happened.When I start the car the warning lamp doesnt come on until I go over 80kph around town it is fine.It has been 6 months now and my question is wether you think the gearbox has the fault or does the ecu have a fault should I maybe swap the modules in the ecu or just leave things alone cheers.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    what does the current trans in the car have ie. 4hdd 5 hdd etc. im not too sure with your post but has the trans been modifyed or anything.
    bye the sounds of it i would just run the computer that works correctly. and the dte could be an issue with the fuel gauge
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    VS calais S2
    May 2010
    when u changed the ecu and got the transmission fixed, what was the fault code coming up as when u done all this to it, with either computer installed???
    vr berlina
    May 2010
    I think from memory they are 4hdd boxes both the same anyway neither were modified the computer from the 95vr doesnt come up with any fault codes only buggers up the distance to empty meter the fault codes were 81 82 which they replaced the solenoid circuits the fault that comes up on the 93 computer now at 80kph I havent checked yet as it disappears after the car is turned off.
    VS calais S2
    May 2010
    to save u piss farting around changing shit that isnīt the problem, i suggest u try to get the fault code out of it whether it be from a tec2 computer or check whilst it has the code when the engine light is on.
  1. VT berlina problems!
    By carljcv in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2010, 06:28 PM
  2. Vr Berlina Ecu Problems (help!)
    By mrlambrou in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2007, 12:04 PM
  3. VT Berlina Problems
    By hazavt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2006, 08:08 AM
  4. VT Berlina Problems
    By hazavt in forum General
    Last Post: 27-11-2006, 04:08 PM
  5. Vr Berlina Problems Please Help
    By Gold_VR_Berlina in forum General
    Last Post: 28-01-2004, 05:40 PM
