Results 1 to 16 of 16
Thread: Help with debadging went wrong. PLz need help
    1999 vs ute series 3
    Oct 2009
    Default Help with debadging went wrong. PLz need help
    Hey guys,
    Debadged my ute the other day and the badge came off but some glue shit satd on and is know hard, its like embeded into the paint and looooks realy ugly, badge is ***d to
    Also the holden badge came off with alot of paint to so was wondering whats the best way to go baout respraying it as such?
    Should i bog it up abit n prime n respay?
    Cheers guys
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    For the paint taken off yeah prob best to do what you said.
    The glue you are referring to if Im thinking the right stuff should be black?
    Its on all of them, what I did was just scratch majority of it off with my fingernail then just got some metho on a towel and rubbed till it all came off. Worked a treat. Only a very very faint outline on the back now. Oh also, get a blowdryer/heatgun onto it to soften it up first.
    Good luck.
    Oct 2009
    the glue is like a orange colour, its hard as a rock
    tried heaps of different things but only way to get it off is to scrtch it off i guess, damm series 3 badges
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by antoniomazzurra View Post
    The badges I have removed had a black double sided tape. Yours must have been re-stuck with somthing else. You could try a bit of paint thinners to soften it a bit.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Vy 04 Series 2 Cosmo
    Nov 2009
    Methy spritits, or if u can get your hands on some ethanol, just wash it off quick, I dont know if it'll go yucky on your paint
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    grease and tar remover from autobarn..
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    VS V6exec
    May 2010
    NSW sydney
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    prepsol, which is basically what decider suggested, glue and tar remover. soak a rag in it and dab it on the tape till its all saturated, then itll rub off with the pad of your finger. watch out though cos' it (or thinners) will soften the paint, so if you get impatient and use your fingernail it could bite down and take a chunk off.
    with the paint coming off, personally i would just touch it up. i suppose it depends on how much cam off. but anything up to an inch or two can be pretty easily hidden with globs of paint.
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    Just sand around the area where the paint came off a tiny bit then just put bit of paint down, wait til it's properly dry, cut it back and it should look pretty good.
    Oct 2009
    ok thnx for all the replys. gonna give this a bang asap, looks like shit atm
    The standerd white for commies is herion white to my knowledge??
    cheers
    VZ SV6
    Oct 2008
    Victoria, Melbourne,Croydon
    Oct 2009
    k cheers, werw can i buy touch up paint for it? supercheap? Autone?
    Cheers for the help guys
    vs commodore
    Oct 2009
    Tamworth NSW
    cheers
    Theres a few different whites used on commodores like alaskan white,alpine white etc.Just write down the paint code from under the bonnet and take that with you.The auto shop will have a book near the touch up paint section where you can look up this code and it will tell you which color it is and it also tells you which touch up paint can number to buy, so it will match your colour.
    Oct 2009
    yer i had a look at the colour code the other day. will do that, thnx againa guys
  15. #15
    VS-II Esteem
    Apr 2010
    Tasmania
    I know a tradie who paints houses and recommends using acetone for getting rid of paint and solvents from anything.
  16. #16
    VX Executive
    Sep 2008
    id try sika remove, its made by sikaflex and dissolves sika flex(and thats pretty hard core stuff) also try silicone solvent
  1. Debadging
    By Bobski in forum General
    Last Post: 07-12-2009, 04:58 PM
  2. debadging the vp
    By scouser king in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2009, 11:29 PM
  3. Debadging problem
    By Crossy_014 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2009, 11:12 AM
  4. Debadging help
    By Brin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2009, 12:46 PM
  5. Debadging
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2007, 06:11 PM
