If the tail shaft is spinning while the auto is in park then you have a problem.
It could be that the shifter is not going all the way to the park position at the gearbox, if this is the case the park pin may not be engaging, or the park pin has been sheared off all together.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
