Results 1 to 12 of 12
Thread: engine detailing 3.8L Buick
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default engine detailing 3.8L Buick
    There is the engine to my project car, as i am currently doing the rest, i figure why not tackle the motor.
    I have never 'detailed' an engine before so i dont know where to start, any suggestions?
    Life starts at 200km/h
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Start by giving the engine bay a good degrease and steam clean, then check and replace any lose or damaged fittings, covers, hoses etc. Then get some autosol (or similar polish) and polish up the smooth surfaces on your plenum and fuel rails. That should be a good start for ya, did you have anything else in mind?
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    was thinking about polishing all metal for the bling look, tidying up the loose ends and hiding some wiring. would like to see a shiney manifold
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    also ditch that pod as its only sucking hot air, some msd red coil packs will brighten it up too
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by WogBoyz View Post
    Pod filter already Ditched!! was the very first thing to be removed, what else should i be looking at? engine is generally pretty clean, however there is a fair bit of grease and gunk underneath, i intend to ramp it up and get under there with a high pressure washer.
    should i pull the top half apart and give it a good work over or just leave it? If you have done anything to your engine bay and pics would be appreciated
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    You can get rid of your coolant overflow aswell to neaten up the engine bay, also relocate the battery to the boot.
    With the overflow you can buy a vertical one that sits beside the radiator, looks good i think it comes chromed?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    vz s pack ute
    Nov 2008
    Alstonville Northen Rivers NSW
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Have you got a link? Interested in these as i need a new overflow bottle
    Power is measured in DECIBEL
    VR Wagon
    Oct 2008
    Central Coast, NSW
    After a degrease and a high pressure clean i pulled the inlet etc out as well as the battery, fuse box, etc and cut and polished where they were, i haven't polished any metal yet though. I took the headlights out and polished the radiator support panel.
    Cheers Josh
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by SweetWagon View Post
    SC has a DIY on it.
    The Daily VN T5V6
    355 VN GRP A REP
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    wow, i really like them, i would like to see some custom over flows and what not, would look a treat. Has anyone attempted to clean up the wiring at all?
  1. [SA] WTB: Buick v6 Engine
    By VNAer0HDT in forum Swap / Wanted to Buy / Trade
    Last Post: 25-05-2010, 09:36 AM
  2. Buick Engine to Vz Sv6
    By ILLUMINOUS in forum V6 Development And Modification
    Last Post: 02-05-2010, 08:27 PM
  3. [NSW] WTB VR buick V6 engine
    By Adamvr93 in forum Swap / Wanted to Buy / Trade
    Last Post: 17-02-2009, 06:52 PM
  4. engine bay detailing
    By elemenopee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2009, 08:02 AM
  5. buick engine?
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2006, 10:33 PM
