Results 1 to 4 of 4
Thread: VR to a VS Ecotec V6
    JGlinatsis is offline Ratty
    Vr Executive 3.8 V6
    Apr 2009
    Default VR to a VS Ecotec V6
    Hey I have a VR and I really just dont like there motor in it its old and sounds like its on its way out soon (Getting Death Taps) so I was thinking of going VR to a VS Ecotec V6 what would I need to do for the switch I have the ECU, the Computer, Looms, the Airbox and all bolt-ons someone said something about the tailsharft so ya I don't really know
    I'm building up a drift car
    VX II Calais LS1
    Jan 2010
    a V6 commodore drift car...?
    You will pretty much need everything from the VS engine bay.
    Tail shafts should be the same.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    Vr Executive 3.8 V6
    Apr 2009
    ya I know but I might go another way with the Drift thing I just love power and sliding thing's
    what shit will I need like will all my power steering lines fit?
    I have never done a motor switch on a holden If done it on a 96 futura to a 95 xr6 (went sick as with a bit of work) and I'm not the kind of guy that can read a lot and then do it I need to play with it a bit haha
    but I do need to know what will need to be changed
    so i can buy it before I start so I know how much I'm out
    VS L67
    Sep 2007
    BrisVagus
    I am helping a mate do a ECOTEC into a VP wagon.
    These are the changes that we have made.
    1. If it is auto and staying that way use the engine to gearbox mounts from a VS and the flywheel cover, this bolts straight up.
    2. Use the ECOTEC exhaust manifolds, ours bolted straight to the existing exhaust system, this maybe different if the exhaust is non standard.
    3. Made a bracket for the kick down cable that now runs across the top of the plenum.
    4. Tapped a fitting into the plenum for the MAP sensor.
    5. Used VS power steering lines, these fitted perfectly.
    6. Mounted a power steer reservoir to the fan shroud.
    7. Extended some of the wiring loom to reach the sensors on the ECOTEC.
    8. Changed the alternator plug to suit the ECOTEC
    9. Used a VS throttle cable to get the length right
    10 Used a VS air pipe from the air box to the throttle body.
    11 Used a standard VS top radiator hose
    12 Removed the air temp sender from the Buick and tapped it into the ECOTEC plenum.
    13 Used a VS starter motor not sure if you can use the Buick one, ours was stuffed anyway and needed replacing.
    14 Made a slight modification to the air conditioner compressor, shortened the top front mount tube to suit the ECOTEC block.
    I think that is all we have done to get it in there and running, may have forgot a couple of small things but this should give you a bit of an idea of what you need to do.
    If you have all the parts sitting there and a good tool kit you should be able to do this over the course of a day.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
  1. engine swap from vs ecotec to vr s/wagon(non ecotec)
    By gumby05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 06:33 PM
  2. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  3. Pre-Ecotec with Ecotec Performance Upgrades
    By JA2Z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2009, 10:06 AM
  4. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  5. WTB: RECO VS ECOTEC or ECOTEC STROKER
    By Cursed CX8 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-09-2008, 12:15 AM
Tags for this Thread
