Results 1 to 14 of 14
Thread: VS engine light (!) after replacing tensioner
    Nov 2003
    Default VS engine light (!) after replacing tensioner
    Hello,
    I recenty had to replace my tensioner (the whole thing) due to a large crack forming along it and the belt squeeking.
    The replacement was a success all but the fact that now my brakes are playing up and the exclamation mark engine light is on.
    Anyone have any ideas on how to go about fixing this.
    Thanks in advance
    Matt
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    That means the hand brake is on, even if only slightly, so I would start looking in that area.
    MY RIDE
    Nov 2003
    i tried the handbrake on and off and its not changing that light there is another light with a P in it that goes on and off for the hand brake
    vs commodore
    Oct 2009
    Tamworth NSW
    That light shows a fault in the braking system.Maybe you have bumped or knocked off the wire that goes to the master cylinder pressure differential switch.If this wire is ok,check the fluid levels etc.How do the brakes feel when used?Does the vehicle have ABS?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by darkowen View Post
    Sorry about that, in later models it's the hand brake light. "P" does make more sense.
    MY RIDE
    Nov 2003
    Quote Originally Posted by Brett_jjj View Post
    The brakes are not working as they did before so i am narrowing down to that wire. The fluid is fine i checked it this morning. Where is this wire and how does it connect or how did i get it wrong when i reconnected it
    vs commodore
    Oct 2009
    Tamworth NSW
    The pressure differential switch wire,if broken or disconnected,wont affect how the brakes work.It is just there to turn the dash brake fail warning light on if one of the two brake hydraulic systems in the master cylinder fails.
    Has ther car got ABS fitted?
    Nov 2003
    yes it has abs. just out of curisoty wat is the difference to the problem if i didnt have abs.
    Nov 2003
    hey guys so the problem is definetly the brakes i am trying to narrow down how to fix it.
    i have attached some photos to help explain my situation.
    Attached Thumbnails Attached Thumbnails VS engine light (!) after replacing tensioner-27052010095.jpg   VS engine light (!) after replacing tensioner-27052010099.jpg   VS engine light (!) after replacing tensioner-27052010102.jpg   VS engine light (!) after replacing tensioner-27052010101.jpg   VS engine light (!) after replacing tensioner-27052010097.jpg
    Nov 2003
    the first pic is the tensioner itself
    the second is the little plug at the bottom of the brake fluid system that when removed makes the light go away but doesnt stop the brake problem
    pic 3 and pic 4 is the brake fluid system
    pic 5 is the wire that is on the bolt of the tensioner that i thought might have something to do with the brakes or could be causing the problem
    Nov 2003
    also when i push the brake when the car is off the vacuum works
    then as soon as i start it the brake pedal goes loose
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    From the pix it looks like you have no brake fluid in the master cylinder reservoir - if so you will be pumping air.
    Nov 2003
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    try moving the earth wire back to the nut it self. it looks like it on the alloy tensoner. it may be an earthing issue.
    also try reproducing your steps, it maybe something you did on your tensoner job
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
  1. Replacing the Tensioner Pulley - V6
    By FXST01 in forum Holden Commodore How-To's
    Last Post: 14-01-2012, 08:48 PM
  2. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  3. Replacing Tensioner...any hints?
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2007, 10:41 PM
  4. Replacing dash light AND radio light
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 05:39 PM
  5. replacing bearings on Drive Belt tensioner Pulley
    By turkeychicken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 01:23 PM
