Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Water Temp/Water Pump?
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Unhappy Water Temp/Water Pump?
    Hi there people,
    Would like your views on this one for me. Driving along motorway today, temp was fine, sitting just below the 1/4 mark like always, into town, round town, lights, stops, starts etc, normal town driving, thats when I noticed the temp rising, got up to just under the 3/4 mark.
    Stopped, popped the hood, water level in the overflow bottle was fine. Started and ran fine, temp back down to just below the 1/4 mark again. Back onto the motorway ( home was only 5mins drive away ) temp didnt move, got home fine, then thought whats it like at just idling. Sat in the driveway for a minute, and temp started to rise slowly. My question is, Is the water pump on its way out? Cheers.
    vs commodore
    Oct 2009
    Tamworth NSW
    It sounds pretty normal.When you are sitting in traffic the engine coolant gets hotter as theres no air flowing through the radiator.As soon as you start moving the temp will drop again as the air starts to cool the radiator.It probably wouldnt hurt giving the system a flush with a garden hose (make sure the vehicles heater is in the hot position whilst all this is done),once the water running out of the engine is clean, then add some fresh coolant mixed at the correct ratio.The thermostat could need replacing,(they are cheap to buy).And so is a new cap.And cleaning out the core with a hose so air can pass through the fins properly always helps too.They get full of dead bugs and rubbish.Hose it out from back toward the front of the car.Cheers.
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Thanks for the reply. Yeah thats true what you said about the temp when sitting in traffic, but its never done that before. Driving in Wellingtons traffic can be slow, if not stand still at times, and its been fine since ive had the car. Does the water pump make any noise when its on the way out??
    vs commodore
    Oct 2009
    Tamworth NSW
    Yeah it will get noisy,you can check the bearing by removing the fan belt and spinning the pulley.If it feels rough to spin,the bearing is buggered. It should feel dead smooth whilst spinning it by hand. If it has any play in the pump shaft, you can also say its buggered. The noise and feel will be the main telltale signs.Also theres a hole at the bottom of the pump to drain any coolant that has leaked past the pump seal when it gets worn.Look to see if theres any evidence of any coolant thats been leaking out of this hole.If theres marks there from leaking coolant,its another sign the pump is old and needs replacing.
    VB SL/E
    Dec 2008
    Was the A/C on?
    I had a dirty condenser which gave me similar problems in traffic.
    Water pumps don't usually have problems with flow, either the seal or the bearing goes or the shaft snaps and it stops flowing all together.
    Also are your fans kicking in?
    Either way sounds like air flow problems.
    Hot House VY SS
    Jan 2010
    The stock water temp gauge should not move once up to normal operating temperature, unless there are other mechanical issues.
    I'd be getting your coolant tested for exhaust gases (blown head gasket) or checking the thermostat.
    Are you having to top the coolant up at all?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Quote Originally Posted by ARATIC View Post
    BULL SHIT that said, all i can say is these vr vs temp gauses have a small tempture in range. 1/4 is about 90 deg c and 1/2 is about 100 deg c, 3/4 is 115 deg c which is all fine. if it was a vt or onwads i would beleve you
    a/c on it will be maintained at 1/4 roughley
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Hi there people, A/C wasnt on, and when I have used it in the past, temp gauge didnt go past the 1/4 mark.
    Have checked the levels, overflow is at the full mark, and radiator level was full.
    Is there a way to test to see if the elec fan is kicking in at all?
    Will do a flush and then get a tset done for exhaust gases.
    Thanks.
    95 VS 3.8lt 5sp Sedan
    Apr 2010
    I have had same problem car overheated in town once, turned out it was the water pump had failed. Got that replaced and it did it again?? I have flushed system twice and gone over fans to make sure they kick in etc (as far as i can tell they do) but it still gets up to the 3/4 mark?? I'm still trying to figure what it is although I will have to try out the condenser... and chech exhaust. If you figure what it is can you email me?? Cheers
    Vs wagon
    Mar 2010
    south yarra
    Quote Originally Posted by NV-MY-VS View Post
    how does the exhaust affect the car over heating?
    if you have already changed a water pump id be checking your thermostat is actually working and opening when its spose to.
    check thermo fans are working.
    ive heard of fans wiring getting stuffed up when people change something and the fan goes into reverse and pushes hot engie bay air over the radiator and that heat it up even more. not sure how true this is?
    are you actually using enough cooloant?
    have you got a block in the system?
    get it pressure tested and go from there.
    and as for a cars temp gauge not moving once warmed up that if fine for VT onwards but the vs usually bounce all over the place from 1/4 on highways to just over 1/2 way in traffic.
    do wat i did and get the colder thermostat. mine hasnt ever gone over half way even in traffic since i got mine. still does the usually fluctuation depending on driving conditions but even in summer in peak hour traffic it didnt reach half way.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by moff_man View Post
    Spot on!....mine regularly goes to 3/4 before the fan kicks in and has done that for the last 7 years. It's crazy replacing parts when it will make no difference.
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Hi there folks, thanks for all your replys so far. Some good ideas to try out. Have done a search on here about flushing the system, can someone tell me the best way to flush it? Is it like my old VL, just drop the top and bottom hoses, and put the garden hose in and wait till the water runs clear?
    This is the first time that the temp has gone above the 1/4 mark since ive had the car, almost 2 years now, thats why I am asking theses questions.
    Thanks again.
    VS executive
    Jun 2009
    mine also hits 3/4 whilst idling or in slow traffic unless the aircon is on , you can just hear the thermo fan kick in then it starts going back down again.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Since every car is different and what you describe is normal for the VS, but, and it is the crucial but, you say it isn't normal because it hasn't done that before in the 2 years you have had the car. Therefore it must be a problem somewhere.
    Have you flushed the cooling system since you have had it? Coolant does deteriorate over time, not the coolant itself, but rather it picks up contaminants from the engine that decrease it's effectiveness.
    The best way to do it is to remove the top and bottom hoses and reverse flush the radiator by running the water into the bottom and letting run out the top. Do that until the water runs clear. Then remove the thermostat and refit the housing and run the water through the engine, it doesn't really matter which direction it runs, do that until it runs clear. Refit the thermostat, a new one preferrably, and refit the hoses and refill with coolant, making sure to bleed the system.
    If that doesn't fix the problem, then it may be the waterpump or the actual radiator that could be partially blocked.
    Visit my Facebook page
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just noticed you have a V8....maybe you need to check the engine driven viscous fan...if the viscous fan clutch has failed , the fan will free wheel and you will get no cooling when stationary. I think you can check by watching how fast it stops spinning when you turn the engine off (if it keeps spinning it means the fluid drive bit is not working)
    See this link on how they work:Thermostatically Controlled Engine-Driven Fan.
  16. #16
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Hello again people, Have just done the flush etc, and noticed that the fan was easy to spin by hand, and like hako said above, it kept spinning after the engine was turned off? So is this just a case of having to replace the fan?
    Thanks for all replys so far, have all been a great help so far.
  17. #17
    moff_man's Avatar
    Nov 2008
    also when cold like ice cold the fan should have high resistance when trying to turn
  18. #18
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can probably just buy the centre viscous clutch which the fan bolts onto....not sure what it costs but it won't be cheap. I'll scout around and see what I can find.
    Edit....one on Ebay 2nd hand starting at $20 and a brand new one here for under $100. Your problem with the temp rising when stationary will definitely be caused by the fan.
    http://cgi.ebay.com.au/Holden-VH-VK-...item5887d64653
  19. #19
    VB SL/E
    Dec 2008
    Should that be the other way around?
    Like the whole point of having the clutch hub is so that it puts less load on the motor when cold and locks up more as it heats up to pull more air???
    Anyway I doubt there is anything wrong with it unless you can see signs of the fluid leaking out.
  20. #20
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by VR38 View Post
    These fans fail not necessarily because they leak the silicone, it's usually the bimetallic coil that controls the action (or reaction) of the silicone by sensing the air temperature that fails.
    But the reason for failure doesn't really matter - if it keeps spinning for a few seconds when a warm/hot motor is switched off then it is not working correctly. If it stops spinning shortly after switching a warm/hot engine off, then it should be OK. Just check the link I posted previously.
  21. #21
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Hi there people, well car went in for a WOF today, and while it was in there, got them to look at the issue at hand. They pressure tested it, was fine. They then noticed there was a small amount of play on the shaft of the water pump, and that the fan did keep spinning after it was turned off after coming up to temperature.
    So its a new pump and fan hub that is needed. Will update when its done.
    Thanks for all your replys.
  22. #22
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Hi again, question, can someone tell me if the fan hub off the V8s are the same as the ones off the V6s? Thanks.
  23. #23
    VS-II Esteem
    Apr 2010
    Tasmania
    I used to have an 80's model Toyota that ran on a viscous/clutched fan. When I first brought it, it used to over temp something shocking. Replaced the fan with a good one and the temp stayed within a good range forever after.
  24. #24
    toyota lexcen - vr.
    Jan 2009
    victor harbor
  25. #25
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    Just had my waterpump and fan done, while they were doing it, they noticed that there had been a small leak on the outside corner of the inlet manifold. Anyone had this problem before as well?
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. Electric oil temp and water temp gauges
    By FRESH_VR in forum General
    Last Post: 02-09-2008, 04:27 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. Water temp??
    By Robbo74 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-10-2004, 09:54 PM
