Results 1 to 9 of 9
Thread: Vr Series 1 & 2 Fuel Economy
    calebsnodgrass is offline Not defected... yet
    VR Commodore Executive, Series I, 3.8L
    Mar 2009
    Kadina
    Default Vr Series 1 & 2 Fuel Economy
    Ok so I have a VR series 1 in a little worse condition than my brothers series2.
    Worse condition as in the engine bay is dirty but completely stock.
    Now on a full tank of petrol which for both cars is a tank of 63L i will get around 400-480km depending if I grandma it or if im a teenager.
    Now my brother is more of a hoon than me pretty much flogging his most of the time yet he gets 500-600km.
    Is this something to do with the engine or should I start to look at the fuel filter, spark plugs, injectors etc??
    Any help is appreciated.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    nice idea to keep the thing serviced and see how you go.
    ive just stumbled apon why my vr was chewing fuel. leaking radator, for some reasion before i changed the leaking radator it read under 1/4 and my cont fuel was at 10l/100 at 50km/h with a/c on. now i get 7.9 const l/100 with a/c on and temp gauge sits bung on 1/4 same speed and same day and same road. radator was only changed
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    I have a series 2 and get around 500 - 550 off the tank, possibly 600 if i pushed it to the bottom of the tank, however this is a mix of city and highway. My friends VR which is series 1, got over 800 off the tank when we drove to adelaide (all freeway), i know he gets around 500 also usually. So it isn't a series issue. You might wanna look into the leaking radiator, my fuel cap was dodgey and my fuel economy dropped like crazy, now i replaced it im using 2L less per 100.
    Andrew426: Why how bad is your economy?
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by Kurtp View Post
    my radiator is fixed i was just using it as an example
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    My old VR got approx 600 freeway with a bit of traffic for some reason my VS is heavier then what my VR was.
    vs commodore
    Oct 2009
    Tamworth NSW
    Plugs,leads and coils wear out over time.Its worth replacing them if they are old.Also keep the oil changed plus change the oil filter, and air and fuel filters need regular replacement.Also the filter in the auto transmission should be changed regularly.I do my oil andf filter every 5000 km.I change the air and fual every 10000 km.And the transmission filter every 20,000km.The oxygen sensors can cause bad fuel economy.These usually last until around 100,000 km.After this they can start to give bad readings,which doesnt set an error code,buit will kill the fuel economy,so it might be worth renewing the oxygen sensors as well if they are old.
    Mar 2009
    Kadina
    ok thakyou all for your replies and no my brother isnt 'bullshitting' me cause i am driving it now to test the tank out... His is also completely stock Vr series 2 so there should really be no difference..
    Ill have to check with previous owner if oxygen sensors have been replaced as its on 260k+ so that could possibly be the problem..
    Jan 2008
    I get arount 9l/100km in my vr driving normally on the open road. The best I have ever gotten driving the VR hard though (eg a 250km trip in 2 and a half hours) was around 13-14l/100km. Which makes me suspect of anyone claiming to drive a vr hard and still get 500-600km out of a tank.
    That being said though, my vr isnt exactly stock.
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. Replies: 9
    Last Post: 03-07-2009, 04:05 PM
  3. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  4. Poor Fuel Economy (VN Series 1)
    By Tibokan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2008, 11:59 PM
  5. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
