Results 1 to 3 of 3
Thread: V6 Commodore won't start
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    Default V6 Commodore won't start
    Just having a few problems again, just wondering what sensor, if it is a sensor, would be causing a VS V6 Commodore to not start.
    Symptoms:
    • When turn key red dash lights come on but nothing happens there doesn't appear to be any noises
    • Hold the key on for several seconds and car will eventually start after several times of turning the key on and off
      Also the other day this happened so i clutch started the car and had no windscreen wipers, indicators or interior light, i got car home turned it off, turned the key to start and it fired up straight away and all the before mentioned items worked. Strange and bizarre, car has never done this.
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    I forgot to mention that when the car is running, i believe that orange engine light on dash comes on when there is a problem generally, this doesn't appear to be happening.
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the metal key reader around the ignition switch.The key might not be touching it properly when its in the ignition.It also could be a faulty inhibitor switch on the gearshift.Next time it does it,try moving the gear stick a bit and see if it starts then.If it does ,thats the problem.If it makes no difference then make sure the metal contact on the key touches the metal ring around the ignition switch.If that still doesnt make any difference, than the battery in the key head might be flat,you will need to get a new key head.
    Heres a link to a thread about checking for error codes.If you scroll down near the bottom of the posts in the link ,theres some good pictures that show you how to do this test as well.
    ---Checking error codes VR/VS (Revised)---
  1. how to start vr commodore without remote
    By cruzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2012, 11:13 PM
  2. want to start a commodore car club (vic)
    By holden_102789 in forum General Discussion
    Last Post: 30-10-2011, 06:11 AM
  3. VS Commodore won't start
    By otis33 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2010, 11:44 PM
  4. vr commodore will not start!!
    By richie351 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2010, 12:54 PM
  5. vn commodore wont start
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2010, 07:28 PM
