whats the best way to see if your car has a shift kit in it already with out taking the gear box apart
what makes you think it has one?
Originally Posted by Adam Savage (mythbusters)
A good indication is usually if the car refuses to get out of 1st without you physically changing to 2nd. Also can some times chirp lyres going 1st to 2nd if at WOT.
well when it changes gear it kinder gives you a little push back in to your seat and it and it sounds like it forcing the gears together pretty hard
you got enuff transmission fluid in there??? that can cause hard gear changes
