Can anyone tell me the torque settings for the 2 front strut bolts that hold on the stb axle assy, I have seen somewhere that it is 80-90nm then a further 90 degrees, these being stretch type bolts![]()
yes except the torque spec im not 100% on that, the bolts need to be replaced also thats why there streach type.
Originally Posted by Adam Savage (mythbusters)
85nm then to 100nm plus another quarter turn. that with new bolts and struts.
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
