Results 1 to 13 of 13
Thread: How to flush and add coolant for my 1994 VR Commodore Executive?
    Commodore VR 1994 Executive
    May 2010
    Default How to flush and add coolant for my 1994 VR Commodore Executive?
    Can anyone here please tell me where is the hose to drain the coolant from my 1994 VR Commodore exeutive?
    I accidentally took the wrong hose and I think i took the engine drain hose off and started my car, then a pour of engine oil came out............ I guess it won't be a major issue/problem right?
    Just wonder how to correctly flush it, if possbile can someone plz post me a photo on where to locate the drain hose or button for the coolant.
    Thanks alot
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    The hose you took off sounds like a trans cooler line. Was the oil a red colour?
    Also, the hose you want to be removing is the big (50mm) hose going into the bottom of your radiator.
    VS V6exec
    May 2010
    NSW sydney
    maybe there isnt a plug on your radiator, and u just undo the bottom hose that goes to the radiator loosin and it pull off, i couldnt find the plug on my VS ,maybe wear safteys if its ur 1st time doin it you dont want green shit in ur eyes , AND dont start ur car at all while hoses are off thats no good at all
    Vs wagon
    Mar 2010
    south yarra
    the drain hose is located at the bottom of the engine. there will be a big square metal thing hanging down attached to the bottom of the engine usually silver/grey in colour. undo the bolt start the engine and acceletrate to 2500rpm to help get it all out.
    as for:
    itll be fine just leave it. (Y)
    May 2010
    Quote Originally Posted by Andrew426 View Post
    YUP, the oil in red colorur, when i turned on my engine it spills to the ground, do I have to refill it someone before i turn on the engine again?
    May 2010
    Jan 2008
    Quote Originally Posted by EvilMonster View Post
    Yeah probably a good idea, your trans will start to slip if you lose too much. It comes out pretty quick, ay?
    looking fron the front of the car (say, with your knees against your front number plate) there will be a funny dpstick tube near the left rear of the engine. Refill this with approximately the amount that came out. You have to pour it down the dipstick tube. You want ATF (auto transmission fluid) equivalent to GM standard Dextron 3 (DX-3, as its sometimes known) Read the back of the bottle, it will say in the fine print. Once you pour it in, start the car, go for a short drive and park the car on a flat surface. Leave it running and in N or P and check the level on that dipstick again.
    May 2010
    Jan 2008
    VP SS
    Jan 2008
    Hiding in WA somewhere
    is this thread for real!!!!!!!!!!!!!!!!!!!!!!!
    seriously how f@#ken stupid are people
    If its got Wheels or Boobs its gonna cost ya money
    Vs wagon
    Mar 2010
    south yarra
    Quote Originally Posted by excalibur View Post
    i was being totally serious bro!
    lol
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Quote Originally Posted by bandidoben View Post
    as for:
    Ignore this clown EvilMonster. Stick with the advice you are getting from Lance and Andrew.
    May 2010
    all good fix the issue, thx all who helped me.
  1. [VIC] FS or SWAP 1994 VR Commodore Executive Sedan **SOLD**
    By Nackerz in forum Vehicles For Sale
    Last Post: 31-05-2010, 10:42 PM
  2. Coolant flush
    By rob151515 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2010, 12:07 PM
  3. Coolant Flush
    By desruction in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2006, 05:31 PM
  4. coolant flush
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2006, 01:20 PM
