Hi when ever i turn my lights on at night the passenger side is really dim and the drivers side headlight is bright , so i open the cap on the passenger side with the dim light and move the light bulb around a little bit and it becomes bright again , and when i turn off the car for a while and turn it back on the passenger side light is dim again , would a faulty globe be causing this or a dodgy terminal or wire or something , has anyone ever had this happen to them any info would be good thanks .
It sounds like a bad connection ,maybe a bad earth.You might have to remove the wiring connector and have a closer look at the bulb contacts in the connector.They could be corroded or dirty.
Thanks brett will do .
