Results 1 to 7 of 7
Thread: vr v6 oxygen sensor
    vr
    Jun 2009
    Default vr v6 oxygen sensor
    hi all i have an early 93 vr v6 and need new oxy sensor. auto parts store dont have a listing for 93 vr. is the vr a 2 wire and is it the same as a vp sensor?
    Quote Originally Posted by v6monstar View Post
    dude your piston slapping your going to have to titan up your pistons be for you throw a con rod throw the side of the of your engine
    vs commodore
    Oct 2009
    Tamworth NSW
    Yeah,VR is 2 wire.The 4 wire heated oxygen sensors were introduced with the early VS models.
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    Replaced mine a couple of weeks ago in my VR and it was 4 wire - mine only had one where i believe ecotec has 2 sensors? Mine definitely 4 wire in VR '94 model
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip vr is 4wire heated sensor theres heaps on ebay
    vr
    Jun 2009
    yeah just got off my lazy ass and had a look. i get them at trade price of $35
    vs commodore
    Oct 2009
    Tamworth NSW
    I always thought they were 2 wire,well there you go.Something else learnt.Must be the VP that has the 2 wire sensors.
    VR Ute
    Jan 2010
    It usually depends on where the sensor is mounted as to whether it is 2 or 4 wire. The 4 wire ones from VR onwards I think) were mounted further down the exhaust system (roughly near the transmission) and that is the reason they need to be heated, because they are too far away from the manifold to heat up quick enough. The 2 wire ones were used on the earlier V6's from about VN's to VP's (I think , but dont quote me on it) and were mounted in the manifold, where they heat up almost immediately on start up, being very close to the exhaust ports. Having said that though, I have a VR which has the earlier VN manifolds (done by me to overcome the cracking problem in the later VR cast manifolds) and all I did was extend the wires and put the original 4 wire one in the manifold. They are exactly the same thread and it wont hurt it, mine has run fine like that with no problems for over 12 months now. BUT BE WARNED, dont do it the other way around i.e. putting a VN 2 wire sensor into a VR exhaust system, because it will be too far away from the heat source, and cause cold starting problems and run poorly till it heats up. Hope this helps.
    Stugdum
  1. oxygen sensor vs
    By Zipster in forum Electrical Wiring / Questions
    Last Post: 29-12-2008, 02:06 PM
  2. Oxygen sensor
    By AndyVKSSA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 11:32 PM
  3. Oxygen sensor
    By trevmeister in forum General
    Last Post: 19-11-2006, 01:04 AM
  4. Oxygen sensor
    By HOTVR5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2005, 02:12 PM
