Results 1 to 8 of 8
Thread: Installing new spring and shcoks in vs ute tomo, help plz
    1999 vs ute series 3
    Oct 2009
    Default Installing new spring and shcoks in vs ute tomo, help plz
    OK, so tomo im gonna give a go at chucking the new springs and shocks in my 99 vs ute, ive got sl all round with shortend shocks struts and adjustable parnhead rod.
    Ive never worked with car suspension before but im pretty handy with the tools. got a good idea of what im gonna do and was after some tips and ways you guys would do it, ie; have u ever done it before and anytips to make things easier? will be doing backs first and gonna get some pro help for the fornt.
    cheers guys
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Doing the backs is easy, took me about 15 mins on a mates car with live axle seadan. Could be different with ute.
    First, undo the bottom shock mounts on both sides.
    Jack car up on jack points. Take your wheels off.
    Put weight on one side of axle, (I put my foot on hub)
    Get someone to take spring out, and replace with new one if you are both quick enough.
    Repeat for other side.
    Redo shock mount bolts
    This may not be how everyone else does it but it works for me, just don't let the car fall off the jack...
    Nowadays I just use my hoist, but i'm guessing you wouldn't have access to one.
    Good luck
    Ben
    There is no such thing as stupid questions, Only stupid people.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Hope you have some spring compressors!
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Oct 2009
    spring commpressor for the front, yes i will be inveting in some but i didnt think u needed some for the rears?
    thnx for the preply
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    You don't, thats why you put weight on one side of the axle, they will free up and be able to be pulled out.
    Oct 2009
    o i get you know, this is what my plan was,
    jack the car up on the rear till the wheels are just about to come off the ground,
    unblot the shocks,
    jack it up abit more and pull springs out, put new ones in and lower it abit and put new shocks in.
    fit new parnhead rod
    how does that sound?
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Sounds good to me...Pretty much as long as you get the springs out, you will have no problems.
    Ben
    Oct 2009
    ok cheers for the help mate, ill let u no how i go
  1. Spring Help!
    By Dinwoodie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 06:04 PM
  2. iac spring. Help Pls
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2009, 12:05 PM
  3. spring cut
    By hispeedvp in forum Miscellaneous
    Last Post: 12-12-2007, 11:16 AM
  4. Spring the same?
    By adam69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2006, 08:32 PM
  5. spring sag?
    By ciaranvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2006, 11:36 PM
