Results 1 to 4 of 4
Thread: My VS is sputtering bad! (no spark at coil)
    vs
    May 2010
    Default My VS is sputtering bad! (no spark at coil?)
    As stated my VS is spluttering bad and engine violently shudders as I try to accelerate.Thanks to the tips here,I have found that the third coil pack has no spark at all.Other two are fine.
    My question is before I change the coil pack,would no spark be due to a faulty coil pack or would faulty leads/plugs be not allowing coil pack to spark.
    Thanks.
    Darren.
    VS l67 statesman
    Dec 2008
    best way to check is swap the leads and plugs and see if it moves the problem to another cylinder or move the coil to a different spot and if the problem is still the same I would be looking at the inigtion control module ( the plate the coils are mounted to) or if it moves the problem then the coil is dead
    vs
    May 2010
    vs
    May 2010
    Thanks m8.Moved coil to different location and also no spark there either.Will replace coil today.
    One other question is will I do any damage to engine with a 15 min trip to autobarn.Otherwise its a 2hr round bus trip.
    Thanks.
  1. vp coil pack spark problem
    By anth34 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2009, 03:42 PM
  2. No spark from coil in vk carb 02
    By nof42 in forum Electrical Wiring / Questions
    Last Post: 18-09-2009, 08:51 PM
  3. coil pack / spark problem
    By Fr3ak+-- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2009, 10:25 PM
  4. vn with no spark, changing coil packs
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2006, 06:26 PM
  5. Blown Up Spark Coil
    By Brownie_86 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2004, 04:42 PM
