hi guys,
am after some info on fuel pumps,
recently my check engine light was coming on and car started running rough then it would go away. i have recently replaced the dizzy coil pack and dfi module all new it ran fine for a couple of weeks.
now the check engine light is comin on and off i got home the other night after the check engine light came on breifly while driving i turned the car off. came out in the morning to the car sputtering and idling like it had a massive cam then it would nearly cut out. i then tried to start it again and it kept back firing when i would try and rev it i checked all the timing but it kept doing it. anyway i left it for a couple of hours came back and it wouldnt start its kicking over but not firing up i located a cracked spark plug lead at cylinder 1 so i changed all the plug leads with new ones however it still will not fired up i have checked there is spark going to all the plugs so im guessing it may be a fuel related problem ?? blocked fuel filter?? shagged fuel pump? fuel reg??
any feedback would be much appreciated thanks![]()
ive tried that no scan tool will connect with the computer always comes up with an error
faulty fuel pump wont throw the light on the dash or give you a code. if the scanners wont talk to the ecm, maybe thats the issue
Originally Posted by Adam Savage (mythbusters)
yeah i just put a cheapie in it this time i put a bosh one in it last time and it f..kd out aswell yeah ill try this paper clip test thing when i get it towed into work lol im thinking it might just be the timing out as ive had to play around with the timing abit in the past i put a new set of leads in it today but the number one spark plug lead melted a hole through it so had to go buy another lead. its weird cause i used to get a fuel smell when trying to crank it over now there is nothing ill check for injector pulse aswell when i can get hold of a noid light at work ahhh so frustrating lol thanks for the info guys..
okay have checked am getting power to the relay for the fuel pump have changed the relay with a new one have then checked there is no power going to the wires at the fuel pump and have checked there is deffinatly no fuel pumping we did have heavy rain i inspected the computer and it was full of water?? would this affect just the fuel pump as i am still getting spark and its cranking over ?
okay correction i think i was testing the wrong plug there are 2 plugs around the fuel tanks one is a white plug male to female with a purple and black wire neither of those were getting power when accessories were on or when cranking ther other plug going directly into the fuel pump with a orangey colour wire and a black wire this plug was receiving power when turning accessories on and when cranking am i testing the right plug ?
okay what i have got so far ive tested the fuel pump relay terminals there is constant power to the black wire but nothing from the purple one?? aghhh so frustrating
problem solved the water that got into the computer must have shagged it, tried a new computer today and everything fired up!! thanks guys who gave info.
