Results 1 to 19 of 19
Thread: a quick question
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Default a quick question
    i have got my engine out now and is it worth replacing them before i put a new engine. and is there anything else i should do before i put then next engine in
    vs commadore Ute 1999
    Feb 2010
    engine mounts would be good!
    Check the ower steering pump?
    check the C.A.S (on the new engine)
    replacing what sorry? lol do you mean, "my engine out now, so, what is worth replacing before i put the new engine in"
    =-+--One Life, One Chance--+-=
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    i have got a reconditioned power steering pump all ready i will make sure i will remove the C.A.S off the old motor to
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    all depends on what you want to do and what it needs doing.
    good idea is to do the sump gasket and rear main seal. possibly welsh plugs, that way these are coverd and the engine wont need to come out again if they start leaking
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    cool i will check if the welsh plug are rusted in anyway if they are i will replace them
    vr x cop
    Nov 2009
    Mar 2008
    pull your sump off and clean out the pick up and all the other sludge in there,
    i can bet you the mesh screen is full of crap
    i think its one of the big causes of the bearing shells failing ,
    but yeh i'd be doing welch plugs they are only really cheap
    and the rear main might be a good idea if you feel confident in doing it
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    +1 for de sludging the sump, welsh plugs and a rear main.
    I've done them in the car. Far better to do it when its out, and cheaper.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    The only motor I can find is a serias 2 but it comes with the computer and wires so should I have any major problems putting it in
    VX II Calais LS1
    Jan 2010
    use your loom and computer and it should bolt straight in
    i know where another motor is...
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Yer I would have got yours but it was like a 4 to 5 hrs drive to get it any this one I got was only 1hr away and had 170,000 ks on it
    Vs wagon
    Mar 2010
    south yarra
    Engine mounts. Rear main seal. clean sump out. welsh plugs. Give the whole eninge bay a degrease/clean touch up any paint chips. is it manual? check the clutch flywheel go over the whole engine with a fine tooth come see if any earths are not connected wires are stripped, any stripped bolt heads? especially if they are in hard to reach places once the motor is in place. check fuse box make sure no corroded wires/fuses. all the engine bolt ons are bolted up properly. the water pump, aircon. paint the pulleys to make it look new again as well as rocker covers.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    VX II Calais LS1
    Jan 2010
    yep you sure can, it just bolts on to the side of the motor.
  15. #15
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    opened up my inlet manifold on my old engine its like filled to the brim with black oily sludge
  16. #16
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    update
    Done:Put A newer water pump on
    Rocket Cover gaskets
    Replaced Inlet manifold with a cleaned out one
    decreased the engine bay
    Yet to do : servo the auto
    clean out and replace sump gaskets
    replace exhaust gaskets
    thermostat housing gaskets
    problems yet to fix: Striped thread on one of the fly wheel bolts
    : rounded bolt on distributor
  17. #17
    vs executive s2
    May 2010
    Dynotune it, once you have got it running.
    They will find any bugs???
    The money well spent once they MAP the ECU...
  18. #18
    vr 3.8ltr
    Oct 2009
    Default vr irs to solid diff
    does any one no if a vr irs can be converted to solid diff?
  19. #19
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by VRskidRIG View Post
    start your own thread mate.. and no it cant be done.. well not unless you want to chop out the whole floor pan.
  1. Quick Question for a Mod
    By Kikki in forum Site Feedback / Site Problems
    Last Post: 01-08-2008, 01:56 PM
  2. Quick question
    By Burniehoon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 12:48 PM
  3. quick sub question
    By Gunns VC in forum Car Audio
    Last Post: 23-09-2007, 07:26 PM
  4. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
  5. quick question
    By littlemissVN in forum General
    Last Post: 06-05-2005, 10:48 PM
