my manual pedal assembly has a crack in it and i wanted to know if there is anything i need to know when changing it? like losening f the clutch cabe? wat about the brake booster? will fluid come out?
cheers
no brake lines have to be unbolted so it shouldnt leak oil,
just losen the clutch cable and lay down if your foot well its easy
thanks for the help... so there is nothing i need to loosen off for the brakes?
