Results 1 to 6 of 6
Thread: Vr - reverse problem need help
    VR Commy
    Dec 2009
    Default Vr - reverse problem need help
    hey hows it going i got prob with my VR the car drives great an all..
    people say its a comon problem with commys but i dont no..
    when you 1st switch on an shift back too reverse as u put the foot to the pedal it somtimes konks out
    doesnt do that in any other gear in any other times just on slow start when you 1st reverseing
    unless you hit the gas on reverse for a kwik high rev if not it'l stop gotta start up again an reverse out..
    does anyone no any help advice would be appreciated....
    cheers....
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Ive noticed that is common in the buicks when power steering is under heavy use whilst reversing. There is no fix that i know of.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try cleaning the throttle body and the Idle Air Control valve (IAC).....it's the IAC that controls the idle and should raise the idle instantly when extra load is put on like aircon, full lock and going from N to R/D. If it's dirty it will act sluggish and fail to raise the idle.
    VR Acclaim
    Sep 2008
    Kingsley WA
    I agree with Hako. I had this problem last year. I've had the car since new and with 192,000 km on the clock the engine would occasionally stall when shifted to reverse. A clean of the throttle body and IAC valve fixed the problem. It had not been cleaned before.
    vs executive s2
    May 2010
    Thanks gents
    my VS does it too
    and now i will have a look at what you have said.....
    Cheers KB
    VR Commy
    Dec 2009
    thanx allot for the replys much appreciated... hako will try that tommorro & reply with results...
  1. Reverse into drive. Is this a problem??
    By Kiifu in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2010, 06:36 AM
  2. vs ute reverse light problem
    By bhagl1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 12:45 PM
  3. Reverse problem :( VRV6-T5
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 07:19 PM
  4. VH reverse light problem
    By robohsv in forum Electrical Wiring / Questions
    Last Post: 09-05-2007, 11:53 PM
  5. reverse light problem
    By michaelrocks36 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2006, 08:20 AM
