Results 1 to 22 of 22
Thread: does this sound right ? ( fuel consumption)
    VS executive
    Jun 2009
    Default does this sound right ? ( fuel consumption)
    ok so i filled 30 litres with 91 unleaded + a bottle of octain additive and managed 240kms city driving the other week ( with a fair bit of heavy foot in low gears at one point).
    next i put 15 litres of unleaded 95 which i usually run it on and only got 80 or so k`s from that ( 40 of those k`s had 4 passengers which would have been about and extra 350kg or so).
    i noticed a fair drop in power with 4 extra people in the car ofcourse so im guessing the engine was labouring a fair bit.
    i cant do the math here , does a labouring engine really use that much extra fuel?
    EDIT: i should add that the 80ks driving on 95 was granny driving as i had passengers and it was pissing down.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    there is something wrong here! fully loaded car shouldn't make it labor, Ive towed a vq statesman with a vs exc v6 on a trailer and it didn't relay labor, i knew it was there but had plenty of power to pull it. 5 people in the car shouldn't be noticeable.
    is your fuel gauge accurate? my vr 2 wagon gauge is all over the place down the lower end of the tank, which is what all my vr's and the olds vs do.
    80km is only 40km less than the half of the fuel you used to get 240 out of 30L if you get what im saying
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    VS S2 Berlina
    Jan 2009
    Sounds about right. My car runs great but even with my lard ass 120kg Cousin its noticeable, 0-100 probly adds an extra 1-2secs. Drivin around town startn n stoppin with that much weight would do it. Plus doesnt really sound like the car had enough time to adjust to 95 octane to get any economy benefit, but i may be wrong there. 1st Gear is horrible on fuel. I have one hill on my regular drive that by doin 90 i use 15% less fuel than at 70k, you really need to average over time to get an answer on how economic your car is. Temperature also effects it a fair bit, I find in summer i use nearly 20% less fuel cause car is running leaner and doesnt take as long to heat up for short trips
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    i only got about 430 to 450 km out of a full tank and that's city drive top speed of 70kmh with a stuffed engine that had oil problems
    vs executive s2
    May 2010
    Default does this sound right?
    yes but no
    which 95 octane did you buy.
    use only the big 4 95 Octane (BP, Mobil, Shell & Caltex ) cause the other crap stations pump out shit and alot of them with water or ethanol with the petrol.
    I only run on 95 and get the same kays roughly under all conditions.
    if i now put in 91 unleaded i will get 80kms less out of a tank. No S**t
    95 is smoother and you definately get that bit more power, ie instantly no hesitation.
    Dont why it would be labouring then, like moffman said somethig else might be wrong.....
    VS executive
    Jun 2009
    Quote Originally Posted by moff_man View Post
    yeh fuel guage starts going funny under about a third of a tank.
    1998 vs s3 ute
    Jul 2009
    near blacktown
    i put about 17 litres of 95 in and get about 120 ks around localtraffic lights and stuff and i give t to the car andi got ***ed lifters an i had 2 ppl in the car and that ethanol crap it really isnt worth getting at al its cheaper but you use twice as much and y car gos like crap on it
    Custom VL commodore(sold regretfully) + VR project
    May 2010
    Newcastle
    my fuel consuption is unbeilable barely 250km for 60ish litres not very happy gonna get new injectors and hopefully that will fix cause im pretty sure the little o rings on my injectors aint sealing properly and they look horrible
    mmm loving my VR
    VS-II Esteem
    Apr 2010
    Tasmania
    God with those poor economy figures i'd be either checking and/or replacing your camshaft sensors, get an efi tune or seriously be looking at your auto's and change your driving habits. I've got a VS-II Esteem and driving it normally gives us a good 10KPL+ and that's in varied loads/driving. We've got lots of country/highways and sharp corners that go for many K's. When we put in 20 litres of fuel, we easily do well over 200K's on it. We test it time and time again, and we're really amazed by the economy on her. She's got 230,000K's on the clock and hasn't had a major service in some time but still drives real well and delivers good performance.
    regards!
    May 2010
    Newcastle
    dont have an auto haha all sensor have just been replaced and the engine has only done 160000 kms ill let you know how it goes after i change the injectors though my dad had the same problem and after changing them fuel economy went back up to around 700 kms a tank
    mmm loving my VR
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    I get 200 from half a tank and about 430 full Locally, 650 on freeway
    but I think my oxygen sensor is buggered because its over fueling
    VS Berlina
    Jul 2009
    Melbourne, VIC
    Yeh I just reset my electronic fuel consumption each time I fill up and then watch that number climb to know when it is time to fill up again as the fuel gauge tends to be a bit all over the place
    VR Executive Series II Sedan
    Mar 2011
    Im trying to figure out why my VR goes through 60L in 300KMs.. Should i look at fuel injectors and oxygen sensor like these guys?
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
  15. #15
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    4 people in a car you are deffinaly going to notice it. I mean fully grown blokes would be an average of say 85-90kg each? include urself and u have an in car weight of like nearly half a tonne. So to say having people in a car shouldnt make any difference is a load. As for the fuel, check your zorst for black soot, give the inside a clean and then drive it for a day or 2. If its all sooty again and you know its not burning oil then its unburnt fuel and its O2 sensor time. My VR O2 sensor was rooted and the chrome tip would turn solid painted black within 4 days
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
  16. #16
    1997 VS Ute series II
    Nov 2010
    Newcastle NSW
    best i have gotten from a full tank of 95 unleaded was 380km's. driving as lightly as possible.
  17. #17
    VS Executive S2
    Aug 2010
    melb
    I'm lucky to get over 350k's to a full tank.
    Usually around 300k's in flat out chokkas bumper to bumper city traffic.
  18. #18
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
  19. #19
    VS Executive S2
    Aug 2010
    melb
    Well what the hell an I doing wrong?
    No error codes. Might have to clean the MAF.
  20. #20
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by Krilnik View Post
    A car under load always uses way more fuel than a car cruising. even if you're light on the foot, stopping and starting is gonna kill your economy, you need long stretches of cruising.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  21. #21
    VS Executive S2
    Aug 2010
    melb
    Yeah I'm very light footed in an effort to conserve fuel.
    I still don't get great economy like some people in similar driving conditions.
  22. #22
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    i get 500 to a tank on avrg
    Quote Originally Posted by pillzor View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. VY S Pac Fuel Consumption
    By christopherVYpaul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-08-2010, 04:16 PM
  2. VL 3.0L fuel consumption
    By shaun69er5 in forum General
    Last Post: 05-03-2010, 02:27 PM
  3. Fuel Consumption
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-06-2009, 09:00 PM
  4. fuel consumption
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 10:51 AM
  5. How is your fuel consumption?
    By luvmycommodore in forum General
    Last Post: 10-09-2005, 07:42 PM
