Results 1 to 2 of 2
Thread: Lowering a vs wagon
    VS 5SPD WAGON
    Mar 2009
    Default Lowering a vs wagon
    Hey there people,just want some info and advice on lowering my wagon.The old girl seems to be suffering somewhat from the dreaded wet sponge syndrome,youve nearly gotta pick the arse end up and lift her around the corners,but anyway,whats the best way to go,buy a set of new lowered springs ,or pull the old ones out and have them reset and retempered?Ive checked some out on ebay for around the $400 mark,which would lower it about 35mm.I also wouldnt mind putting a set of 16by 7 rims and would also like to know if I would create clearance issues.Any advice would be much appreciated.Cheers!!!!!!
    Vs wagon
    Mar 2010
    south yarra
    ebay there is a guy that sells a kit of king springs front and back, front struts and rear shocks for $630.
    Choose the hieght. you can either get lows, super lows, or ultra, depending on how low you wanna go.
    They are also heavy duty springs so the ride is a bit firmer.
    If you are going to go to super lows or ultras you will also need an adjustable panhard rod.
    16x7 will be fine. guys on here run all the way up to 20x8.5 on there cars so you will be fine.[/
  1. Lowering my wagon
    By Zend3r in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-09-2010, 07:12 PM
  2. Lowering the Wagon....
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2009, 10:56 AM
  3. Lowering My Vy Wagon
    By FOTO_WAGON in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-05-2007, 03:02 PM
  4. lowering a vt wagon
    By totality in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2006, 05:31 PM
  5. Lowering my VP Wagon
    By ChrisVPCommodore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-07-2005, 10:11 PM
