Is it the rear seal or can there be a leak from above at the rear of engine. Doesn,t leak at idle only when revs are increased. Checked rocker cover gaskets no leaks, checked oil switch at filter no leaks , removes auto cover pan to acsess rear seal oil coming down from this area.
check if the PCV is blocked
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
rear main seal.
gearbox or motor has to come out mate.
