Results 1 to 19 of 19
Thread: wtf have i done..... help
    vr acclaim wagon, vs wagon (project) & vx belina
    Apr 2010
    brisvegas
    Default wtf have i done..... help
    well went to replace water pump on the bargin vs i baught yesterday.
    see pics
    i thought the spout that has a hose coneccted to was apart of the water pump, clearly its not, i levered the pump to get it out and it snapped ... see pics.
    how will i fix this any ideas, or is there a piece snapped off ? all help appreciated. thanks
    Attached Thumbnails Attached Thumbnails wtf have i done..... help-031.jpg   wtf have i done..... help-030.jpg   wtf have i done..... help-025.jpg
    VS executive
    Jun 2009
    im comparing pictures from this thread Changing water pump VN/VP/VR and it doesnt look good.
    im guessing thats an outlet so however it goes back on its going to have to be water tight and on ****ing good!, but again i dont know much about this stuff so wait for someone that knows exactly what to do!
    vn commodore
    Jun 2010
    you might be able to use some high heat quick steal but that will only be a quick fix it could last a week or it could last a year all goes on how good you do it
    VS executive
    Jun 2009
    the thread i posted earlier was for buick 3800 engines aswell ive heard its the same but apparantly from the photos the buicks dont have that part , correct me if im wrong.
    Apr 2010
    brisvegas
    yeah it looks todaly different to a vr, i have 2 in the drivway atm,
    im fairly sure the spout removes but has snapped still attached to car, anyways i taped remaining out with screw driver just need a replacement part, any 1 got a part number???
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    if ur havin trouble gettin it off, have u thought aboutcuttin it straight and welding a pipe on it?
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    Apr 2010
    brisvegas
    yeah thanks 4 that but i got it out with the help of the missus....
    my question now is what is that part number for the spout,,,,,,,, it must be a replacable part
    vs commodore
    Oct 2009
    Tamworth NSW
    Just take the old piece with you.The wreckers is probably the best bet unless you want to get a brand new one.
    Mar 2008
    dude that looks like part of the front engine cover
    if it is i think you will have to remove your balancer and everything
    Attached Thumbnails Attached Thumbnails wtf have i done..... help-vr-pump2.jpg   wtf have i done..... help-vr-pump.jpg
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Apr 2010
    brisvegas
    vs commodore
    Oct 2009
    Tamworth NSW
    [IMG][/IMG]
    Looks like yours was corroded and snapped off where the pipe joins.
    Apr 2010
    brisvegas
    thanks for that Brett_jjj , thats just what i need....... where do i find the part number for the inlet pipe
    VP Exec
    Jun 2005
    Any parts store that sells it will be able to find it without the part number. I suspect that it may be genuine only but sometimes I get suprised by what the chain franchises sell.
    I would be trying the wrecker option myself => <<<$$ but it depends on how easy that option is for you; if you are out in the sticks somewhere... You should still be able to find a good one without very much corrosion on the sealing surfaces.
    You do need the correct size 'O' ring also.
  15. #15
    Apr 2010
    brisvegas
    yeah plenty at the wreckers, so i think ill just get a new one prob will come with the required o ring
  16. #16
    vs commodore
    Oct 2009
    Tamworth NSW
    Im not sure if or where you can find it online.Any car parts place like supercheap or even holden will be able to tell you the part number straight away.Just give em a call.Im pretty sure all the ecotec engines use the same heater inlet pipe..
  17. #17
    Apr 2010
    brisvegas
    yeah thansk.... do u know much about lsd diffs, i have one t-ed up to pick up tomoorw, says its a lsd how do i confirm this, both wheels spin same way or oposite
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by glennis View Post
    The same way.
  19. #19
    Apr 2010
    brisvegas
    cool thanks
