Results 1 to 8 of 8
Thread: Replacing Vs Heater Tap
    VZ SV6
    Oct 2008
    Victoria, Melbourne,Croydon
    Default Replacing Vs Heater Tap
    Ok so from my last car service i was told that i had a leak in my heater tap and that it would be advisable in the near future to replace it. Mechanic said to replace it would be $150-200.
    Anyway bought one of ebay for $26. Ive been doing a bit searching around on how to replace it myself. It seem pretty straight forward Disconnect hoses, put the new tap in, tighten the clamps then bleed out the air. Just wanting to make sure this is right or if there is anythging else i need to do so i dont break anything.
    Thanks in advance
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    I just changed my heater tap 2 weeks ago. All together with hoses was $70. It's all straight forward just note down the way the hoses connect to the tap.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    very easy to do and yes just note which hose is where and ur done.
    note: if you only replace the heater tap and not hoses (like me) when u connect it back up and u find it dripping, just cut the end off the hose that has been moulded by the hose clamp and then reinsert and ur good.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Quote Originally Posted by ephect View Post
    Yes its a very easy case of swap the pipes over to the new one , takes maybe 20 mins max to do
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    .....and flush the coolant while the system is open.
    VZ SV6
    Oct 2008
    Just quickly when im bleeding i need to open up the bleeder screw yes?? where exactly is it?
    VS Exec 5spd
    Aug 2008
    the bleeder screw is a the top of the thermostat housing, which is where the top radiator hose runs to on the engine.
    you need to take the engine cover off to get to it.
    VZ SV6
    Oct 2008
    Quote Originally Posted by shifty6 View Post
    Thats probly why i couldnt find it. Thanks a heap mate.
  1. VT heater core needs replacing - AC evaporator too??
    By rantin'n'raven in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2012, 08:46 PM
  2. what is this? (something to do with heater?)
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-09-2009, 10:31 PM
  3. Replacing oil switch (ebay one) and replacing cup holders???
    By BlackCaprice in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-06-2009, 03:50 PM
  4. Replacing Heater Tap
    By boohsv in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2009, 01:05 AM
  5. Replacing heater core - Where abouts and how much?
    By reformed99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 08:30 PM
