Results 1 to 8 of 8
Thread: 97 Calais vs 3.6 boot leaking
    97 calais vs 3.6
    Jun 2010
    Post 97 Calais vs 3.6 boot leaking
    Big prob with the boot leaking; getting in from somewhere and not just isolated to a particular area ie water in the wheel well plus in centre, right & left of the boot floor [not as bad as the wheel well as water obviously collecting there]. Rubber boot seals seem okay and cannot see any rust on welds...; Heeeelp, please.
    Dec 2009
    Quote Originally Posted by MikePee View Post
    I had a VN and the leak ended up being the rear 1/4 windows behind the back doors. I took them out, cleaned them up and resealed them using a non hardening windscreen sealant and no more leak.
    Other than that tail light's are there rubber washers to seal where they attach and is the seal on the wiring loom OK?
    I'd say it's most likely to be your rear 1/4 windows. You have to remove the rear seat, seat belts and the trim to get them out. Seat is easy just put your hand down between the bottom and back and pull the bottom up back first, the way they mention in the manual idoesn't work that well.
    VS V6exec
    May 2010
    NSW sydney
    i had a leak in my VS was running down into the boot aswell, check along the boot rubber for rust if there isnt any check ur Tail lights water can get in from there aswell<--- i beleive its one of them 2 for sure
    vs calais
    Dec 2008
    99% its the rear quarter windows... happens to most vr-vs commodores over time. take them out.. buy some windscreen sealer from supercheap, reseal them, fit back together and should be sweet
    check this out How To Fix A VN-VS Boot Water Leak
    if its not that then its the taillight seals.
    vs commodore
    Oct 2009
    Tamworth NSW
    My VS leaked water in behind the tail lights.The seals were cracked and broken..Also the VS V6 is a 3.8 litre engine,not 3.6.
    1996 Vs Commodore Series II V6 Auto
    Dec 2009
    South East Melbourne
    mine was leaking through right quarter panel window
    took em both out and cleaned em up and sealed them back up with windscreen sealant
    no more leaks
    just take all carpet out and pour a bottle of water over each one and see if it leaks into the boot
    97 calais vs 3.6
    Jun 2010
    97 calais vs 3.6
    Jun 2010
    Thanks...checked out the taillights and resealed plus also the back 1/4 windows....that was the main prob. Took them out and resealed, reinstalled and fixed prob. Much appreciated
  1. vn calais. leaking boot.
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2009, 10:30 PM
  2. Boot leaking
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2008, 03:58 PM
  3. boot leaking
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2007, 05:50 PM
  4. boot leaking
    By ad45 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2007, 04:40 PM
  5. VK Boot leaking
    By VKNutt in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-03-2006, 02:50 PM
