Results 1 to 22 of 22
Thread: VS Commo Burnout
    ETH4N's Avatar
    ETH4N is offline Project VS
    1995 VS Commo
    Jun 2006
    Central Coast (Watanobbi)
    Default VS Commo Burnout
    Hey guys, i used to have a VR commodore, 3.8l, used to be able to put my foot on the brake, and sit there and bag it up, but now i have a VS commodore 3.8, when i sit on the brake and pump the accelerator, she doesnt bag up, barely does a spin, just revs...
    Am i doing somehting wrong??
    LOL
    BTW, these are performed on PRIVATE PROPERTY, AWAY FROM OTHER CARS/PEOPLE
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    grippy tyers, thats all im saying unless it has something to do with lack of power
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    Jul 2008
    iaydemir's Avatar
    iaydemir is offline Donating Member
    VY V6 Berlina
    May 2009
    Was the VR live axle or IRS? Is the VS IRS?
    Its easier to break traction in live axle car compared to an IRS car.
    It's a bit tricky to explain but in an IRS car the rear squats when you put power through, IRS was designed to improve handling.
    Live axle doesn't squat and has no camber, hence easier to break traction.
    VS Executive S1
    May 2009
    My Ecotec VS bags up easy as hell, with that being said it is a live axle model.
    So unless like iaydemir said about the IRS thing, perhaps your car isn't running at it's full potential.
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    go buy your self 2 brake line clamps and put them on the back brake lines problem solved just rember to take them off after your done
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Back in the old FJ days (with a 65hp engine), a mate of mine rigged up a drip feed system which dripped old engine oil on to one of the rear wheels on command. Tyres of course were skinny crossplies usually bald or regrooved. They smoked beautifully and retreads basically exploded.
    Vs wagon
    Mar 2010
    south yarra
    VR / VS totally different engine.
    VR has alot more Torque down low. where as the VS has more top end.
    if you want to just do stand stills on a stock car buy a VR unless you can learn to control it properly then you wont need the breaks as much
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by ETH4N View Post
    ROFL.... suuuure......
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VX S-pack
    May 2009
    hey mate,
    i think most of the reason would be the IRS they bog down when under acceleration and when you try do brake jobs.
    I tried many times with my VS only way to do is start them spinning before you jump on the brake.
    1998 vs s3 ute
    Jul 2009
    near blacktown
    A bicycle
    Aug 2009
    Gippsland, Victoria
    how many revs does it go up to, could be a trans issue.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    VS Commodore Ute
    Nov 2009
    Quote Originally Posted by hako View Post
    HAHA thats worthy of a sig.
    Get a manual and she'll drop bangers no problem
    96 VS V6,98 VT 5.0 CLUBSPORT,VS V8 UTE 5 SPEED
    Feb 2008
    Brisbane Aus-loganlea
    jus hook up ur window washer hoses to the back wheels and feed window washers desil
  15. #15
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    doubt its the IRS my old VR had an IRS LSD and it lit up both rears and just sat there with ease, the VS does them easy enough but not as effortlessly as the VR used to, however my VS is easily quicker on the freeway.
  16. #16
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    While the buick and ecotec are different engines with different torque curves, it sounds more like a trans issue to me as he says it just revs and spins a little. How is your trans fluid?
  17. #17
    Nzpure's Avatar
    Nzpure is offline VS L67
    1997 Vs Supa6
    Aug 2008
    Christchurch
    My filthy old vs wag could get the wheels going easy thinkies theres something wrong with your vs cuz
    You Must Always Remember to Blow on the Pie
    ""Safer Communities Together""
  18. #18
    dumpedvs's Avatar
    dumpedvs is offline sheppa8
    Vx S
    Mar 2010
    my vs bags em up just when you plant it,
    im guessing the mini spool would help a little :P
  19. #19
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    i had a similar prob before i converted mine over to manual......whenever i tried to wick it up the car would just rev it arse and off and slowly creap forward, i replaced brake pads and problem solved, wicked up no problems, i suggest if you want skids though put a manual in it you won't regret it.
  20. #20
    VS Exec 5spd
    Aug 2008
    the tranny in ur vs could be crap,
    maybe the rear vs brakes are working better than ur vr brakes were,
    stickier tyres...
    not really good for ur driveline anyway.
  21. #21
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Quote Originally Posted by Beno1982 View Post
    until your manual gearbox blows up becuase of the skids
  22. #22
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    When my brother picked up his VR V6 he let me test drive it, I planted my foot and it stayed still with a massive smoke screen behind me, no brake needed. His old VS wouldn't do that even though the engine was rebuilt, only get a chirp.
  1. $600 Vk commo.
    By vk.jonno in forum VB - VC - VH - VK
    Last Post: 23-11-2009, 08:44 AM
  2. vr commo
    By fullygreek in forum General
    Last Post: 07-11-2009, 09:40 AM
  3. vn v6 commo
    By cruza in forum Electrical Wiring / Questions
    Last Post: 09-02-2008, 04:24 PM
  4. vr bt1 commo v6 FS .... maybe
    By nathsvrbt1 in forum Parts And Other Items For Sale
    Last Post: 06-02-2006, 02:29 PM
