Results 1 to 13 of 13
Thread: Heater not working in my VS
    05 VZ R8 Clubsport
    Oct 2009
    Melbourne VIC
    Default Heater not working in my VS
    I have the the knob set to hot yet i am getting no heat even when the temp is up so what could be causing that
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    vs commodore
    Oct 2009
    Tamworth NSW
    It could also be a faulty thermostat in the cooling system.If its faulty and stuck open,or if its been completely removed,the engine wont get a chance to heat up to running temp and will just run cold all the time,this also makes the heater blow cold air.This is especially so in cold weather, which is when you want to use your heater the most.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Blocked heater core?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    With the engine warm and idling, and the heater turned on, pop the bonnet and check the heater hoses are warm/hot on both sides of the heater tap (see pix) - should be warm/hot all hoses. Another thing to check is the heater valve switch which is vacuum operated (see pix). Also with blower on, check that flaps work when you change dial from floor to demist etc.
    Attached Thumbnails Attached Thumbnails Heater not working in my VS-heater-vacuum.jpg   Heater not working in my VS-heater-tap.jpg
    Vs wagon
    Mar 2010
    south yarra
    HAKO:
    i have the same problem.
    both sides the hoses in the bay and metal ones under the dash are hot but when i turn heater on its freazing cold air?
    in theat photo what is the heater valve switch?
    Quote Originally Posted by TrikkBen View Post
    Didn't BT1's come with eject buttons
    Quote Originally Posted by wez84 View Post
    And a lowered ash tray
    VE SV6 Commodore Ute
    Aug 2009
    Quote Originally Posted by hako View Post
    i did have this problem it was an easy fix.... in that first pic from hako here, the tread had fallen out of the little arm that adjusts the temp.. check that too
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    If you heater tap isn't faulty its the dial itself. My dad fixed mine. Only took 30mins. You can see if the dial is working from under drivers side. Do you have Climate control or standard? Does the switch get a little stuck at one point?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by bandidoben View Post
    HAKO:
    In the first pix look for the white plastic arm with the steel rod connected to it, the to the left of the bottom of the plastic arm is a black plunger thing sticking out towards the white arm....in the position that the pix is in the heater is on, but when you dial cold, the white arm swings anti-clockwise and presses the plunger in which supplies vacuum to the heater switch and turns it off.
    But if the pipes are hot it means coolant is flowing thru the heater....so that means you possibly have a problem with the vacuum operated flaps which direct blower air thru the heater so it gets hot.
    See if the flaps are working - immediately after you switch the engine off, rotate the mode dial from floor to demist etc slowly - you should hear the flaps opening/closing as you change the setting - there should be enough vacuum left to do this a few times. If nothing happens you may have no vacuum or a line is off.
    05 VZ R8 Clubsport
    Oct 2009
    Melbourne VIC
    VP Commodore Executive V6
    May 2009
    In my VP it was just the medal rod described above, slipping thru the thread in the coupling, so a $1 investment at the local wreckers fixed it, with a new plastic coupling
    Vs wagon
    Mar 2010
    south yarra
    when i change between demister and floor i hear the flaps opening as such all the time. it appear to be working fine just no heat?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    OK - so if both the brass tubes in the first pix I posted are hot, the hot coolant must be circulating thru the heater matrix....can you confirm both tubes are hot?
  1. VT heater stopped working??
    By pl0x in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2009, 06:36 PM
  2. vn heater not working
    By onlinejames in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 12:57 PM
  3. Heater fan is not working
    By vb_commie in forum VB - VC - VH - VK
    Last Post: 07-07-2008, 11:47 AM
  4. How to get heater working
    By hittmann81 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-04-2007, 12:37 PM
  5. heater not working (try this)
    By flyen in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2006, 09:24 PM
