Results 1 to 6 of 6
Thread: healing a lazy throttle
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Default healing a lazy throttle
    Hey guys, i know the buicks are renown for having a fairly lazy throttle, however is there some methods to help make the reaction better. Very annoying when overtaking etc.
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Ensure the throttle cable is functioning a hundred percent. Clean throttle body and check its opening one hundred percent. Not sure if thats what your after but DIY instructions are on here somewhere!
    Mar 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Kurtp View Post
    If you mean that it's a bit stiff and lacks feel then I'd remove the cable and soak it in oil overnight. This will lubricate the cable and make it move smoother. A shortcut may be to just spray both ends where the inner cable enters the outer cable with WD40 and then move in/out. The inner cable is coated with a plastic substance designed to make it move easier but with time it can wear away making the cable stiff to move. (bit like me in my old age!) Good Luck.
    VZ SV6
    Oct 2008
    Newcastle NSW
    Is it the throttle that's playing up or the time for the transmission to kickdown thats the problem.
    Kurtp's Avatar
    Aug 2009
    Pakkey VIC
    I'm getting the transmission serviced soon, so maybe that will fix the shift a bit, thanks for the suggestions.
  1. Lazy VT that has done nothing for 3 years
    By jbourke in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2009, 01:43 PM
  2. A Lazy Arvos Work
    By 308vkcalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-12-2006, 07:21 PM
  3. lazy question about the VK
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-07-2006, 11:46 PM
  4. 304ci vk seems lazy
    By azza009 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-03-2006, 08:37 AM
  5. My Lazy Gearbox
    By PIMPIN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2004, 06:35 PM
