Results 1 to 3 of 3
Thread: Correct cruise control adjustment?
    VS V6exec
    May 2010
    NSW sydney
    Exclamation Correct cruise control adjustment?
    ok i pulled the blinker stalk out and resolded the wires wich were broken, but before i did this i fiddled with the break/cruise switches at the break pedal..people are saying its a very touchy thing and has to be exactly right...basically when the break pedal is fully to the floor both switches need to be off the break pedal??? and when it's reasting normally they need to be fully seated back against the pedal am i correct guys?
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The answer is yes. Plungers on both need to be in. You can easily check the adjustment with a multimeter but be aware that each switch operates differently.....the lower brake switch is open circuit with the pedal up whilst the upper cruise switch is open circuit with the pedal down. Check each switch with pedal up and down.
    If you don't have a multimeter you can check the lower brake switch simply by checking if the stoplights turn off/on with the pedal.
    The upper cruise switch needed a bit of force to push in before I successfully adjusted mine.
  1. need help with cruise cable adjustment.
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2010, 05:28 AM
  2. Clubsport VR climate control Adjustment
    By Shewhomustbeobeyed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2009, 12:54 PM
  3. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  4. VK cruise control adjustment
    By 85_Calais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-11-2008, 11:29 AM
  5. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
