hi i am in need of a new motor i have got broken liters and have been told it will be cheaper to get a new motor i can get a second hand motor supply and instaled for 950 but i am thinking about putting a supercharged ecotec motor in just the factory supercharged motor jst wondering how much it woud cost for suply an install if anyone would have a rouh idea and will i have to change other things im pretty sure i will need the computer for the supercharged motor but i dont really know how much other things will need to be changed as well
thank you for your help in advance
all mounts and such shoud be the same, its the same basic engine with the blower on top, just check how you go for rego and insurance wise, shouldnt be an issue because the vs statesmans had a supercharged option. also the exhaust will need to be modded as the supercharged emgens use a twin cat setup and joins in to one at the back of the trans.
Originally Posted by Adam Savage (mythbusters)
well thats one thing i ddnt think about ill look into that
As far as I know. Engine, ECU, BCM matched to ECU, loom, S/C intake pipes, new exhaust. Also if you can, get a torque converter from a L67 car. I believe it is higher RPM than the L36 one.
Ronald Reagan (1986)
i got a motor , gearbox, ecu, wiring and exhaust for $2000. n fitted it myself.
only other thing you'd need apart from what the others said is the fuel pump.
and can just get ya old bcm linked to new ecu.
motors usually go for $1500-$2500 on ebay usually with wiring n ecu and sometimes gearbox too.
Pretty sure the BCM/ECU linking thing was VT+. I'm gonna play devils advocate, the blocks are the same, the ports are the same, pretty sure you won't need to modify the exhaust.
i 'thought' it was just for the 2nd cat for extra flow. just cause i 'read' lol that single cat was too restrictive. but the old one would line up n it would run ok
you can just keep your normal computer and get a SC 6 tune burnt onto your memcal.
saves matching to the BCM etc.
sounds very interesting this really thinking about it is there much diffrence in power ? to wory about and will the gear box need changing i was about to book a service an shift kit install in today but thought i should wait till after the motor thanx for your help guys
the super 6's Ive driven go like stink when your up it. and you have to rev it. i also love the sound. clean and quite and the wine it has is gourgus.....lol no use having a loud exhaust when the super charger wine will do. also its cheep power. enlarge the pulley and it winds up the boost.
there is and there isn't. there not as quick as a v8 if there stock. but be better on petrol too when cruising around. but there a hell of a lot more tourqy than ecotecs
when i first put mine in i were a bit dissapointed the the power increase when it was standard ('supercharged' sounds so fast lol) but with the 10psi pulley im happy now and thats only 1 little mod. plenty more to go yet.![]()
with the auto im pretty sure the tourq convertor is the only different thing between them (not 100% sure thou)
You don't need to rev the L67 to get it moving. Your torque is generated in the low end of the rev range, usually between 2000 to 4500 RPM. This does change depending on the mods that you have done.
When you want more boost, you use a SMALLER pulley to spin the blower faster, this will create more boost.
To the OP, the L67 conversion is a very easy conversion. The engine and box will bolt straight in with no issues whatsoever. You can use the standard wiring loom, but there are a couple of wires that you will have to extend as some of the sensors are in a different position.
You don't need to worry to much about the fuel pump as the standard ECOTEC one will get you about 300RWHP.
You also don't need to run the electrical boost bypass solenoid.
As others have said use your standard ECU/PCM and get someone like Delcowizard to do you a L67 memcal for it.
If you have all the bits ready to go, you should be able to do the conversion in a day.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
so i will have to get the auto and memcal then ?
will a l67 line up with a t5 box in a vs commo? all wiring match up?
I believe so. Somebody has done it here.
Here you go - Womboin23 http://forums.justcommodores.com.au/...-w-l67-m5.html
i have got a budget of 1500 for this conversion if i have to go over that just goin to put a standrad ecotec in and sell the car because dont want to waste my money on a second hand tranny as i have just got a reco done on it
auto transmission is exactly the same between s/c and n/a. i'd budget more than $1500 though..
The tranny is the same but the torque converter is slightly different. The L67 has a slightly higher stall.
what is the price rang i will be looking a just for the motor and memcal
i got mates who change motors al the time i sorted somethinhg out with them just second hand l67 motor from wreckers
will it still go god for a week or so so i source the parts ??
i forgot to add they have two O2 sensors but they are 4 pin not 2 pin like the standard 2 pins.
so if i went an got the l67 mtor droped it in and put the memcal in i can just drive home or will i need to change the o2 sensors aswell ??
thanx for your help so far guys much apreciated
looking for a motor now if any1 finds 1 in western sydney area pls pm me
