Results 1 to 17 of 17
Thread: Auto Breather Hose
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Default Auto Breather Hose
    Where dose the hose go cause i have looked and i carnt find a place to plug it in to
    VX II Calais LS1
    Jan 2010
    it doesnt go anywhere, just sits on top of the auto.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    dang i was hoping it was the casue of one of my problems got the new motor in and running but its reaving really high before it changes gear unless i back it off its full of oil
    VX II Calais LS1
    Jan 2010
    didnt you use your old trans?
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    VX II Calais LS1
    Jan 2010
    strange.. if your using your old auto would of thought it would be the same as before
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    how about the vacuum hose where dose that go
    yer me to the only thing we did was change the oil and filter and gave the outside a clean oh well looks like it will be going to to the mech asap
    VX II Calais LS1
    Jan 2010
    have you checked the oil level with it running and in N ? could be a little low maybe?? when u changed the filter did you make sure you pushed it in to the valve body as far as it would go?
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    yer i did my step dad just saying give it time give it time it just got to get used of the new oil casue it been running on burnt black oil
    VX II Calais LS1
    Jan 2010
    why was the oil black? have you been towing with it? black oil is burnt from excessive heat or slipping trans
    VX II Calais LS1
    Jan 2010
    hopefully it will come good my car had black oil in the trans when i got it, used to hold gears way to long, 6 months later and 2 services its good as new.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    nar i did not tow with it but i did have a overheating problem with a little while ago and i planed to have it serviced but i never got around to cause i kinder blew the motor and things keeped braking on it
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Was it doing it before the engine swap? Is it every gear that's revving out? Check the oil level. If you put too much oil in it, it can cause too much pressure on the band's as well.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    i am going to take it for a longer drive tonight so i will see if its doing it agian
  15. #15
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    did you reuse your old tps/ throttle body? maybe the new tps/throttle body is buggerd, that would make it hold gears and such.
    also trans should be checked in park, not netural.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
  16. #16
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    no i used the same inlet manifold cause 2 weeks before the motor went i had it cleaned and i always check it in park
  17. #17
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    took it for a nice drive down the highway and for some reason its changing in to every gears nicely now
  1. Fuel breather hose?
    By calais24/7 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-06-2010, 09:29 AM
  2. VN Fuel Tank - Breather hose?!
    By xXBoofXx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 08:16 PM
  3. where does the breather hose on my auto go?ive looked everwhere please help
    By trev-355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2010, 06:11 PM
  4. Where do I run a breather hose from my fuel tank to.
    By bhagl1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2008, 08:30 PM
  5. Breather Hose
    By niggle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-09-2004, 05:57 PM
