Results 1 to 2 of 2
Thread: Series2 v6 problems
    VS l67 statesman
    Dec 2008
    Default Series2 v6 problems
    A mate of mine has just bought a manual v6 VR ute it has all of the symptoms of a massive vacuum leak but without any hissing sounds and runs like it has dead cylinders very roughly but will start to smooth out a higher revs
    I tried spraying WD around the motor to find any vacuum leaks without any success ,also all leads and plugs have been checked and we threw on a set of 6cylinder ford injectors which helped a bit ,another symptom is at times it will just flood and refuse to start even though it has spark
    finally the motor is supposed to have been rebuilt at some stage with a cam so we are starting to wonder if it has a burnt valve or the timing hasn't been set correctly
    ANy ideas?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    ford injectors is fail pull them back out fit the stockers then check that the fuel pressure reg isnt leaking fuel out the vacuam hose
  1. VR series2
    By im blonde? in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2009, 05:22 PM
  2. VS series2 HSV 5.0l street car
    By showtime in forum Vehicles For Sale
    Last Post: 25-09-2008, 10:57 PM
  3. My VT Calais series2
    By sus_calais in forum VT - VX - VU - WH - V2
    Last Post: 13-11-2007, 10:30 AM
  4. series2
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2006, 11:39 PM
  5. vy series2
    By Garth in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-09-2004, 11:49 PM
