does anyone know if u can put a ve steering wheel into a vr
As a bolt on mod, no. With alot of customising then yes. Not that you'll be able to hook it up to your vr to actually work, but a ve airbag will set you back $500.
thanks for the reply. i forgot to mention its a vr r executive so i wont run a airbag
Splines on the VR steering shaft will not match the splines on the VE wheel. Shaft/spline changed with VT.
would a vt steering colum fit in a vr or would it b to long
