Results 1 to 5 of 5
Thread: Possibly starter motor problem??
    1997 VS SLR 5000 5 litre
    Sep 2007
    Default Possibly starter motor problem??
    Hello everyone, now and then when i start my car it makes a grinding/screech sound now my machanic said it is most likely my starter motor??? the sound comes from the right side of the motor around near behind the battery area?? any ideas?? thanks all
    Tom
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    sounds like the starter drive is dry, and coved in dust and crap. remove the started and give it a clean and lubrication and should be fine
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    Sep 2007
    thanks moffman Were abouts is the starter motor located?? Its a 5lt VS by the way cheers
    moff_man's Avatar
    Nov 2008
    passangers side, i just had to double check. the old 253's and 308's had them on the passangers side and these blocks are the same with the prefex 5.0L stamped insted of the 308. my vl 5.0 (when i had it) was on the passangers side.
    VZ HSV Senator, VL calais RB25 turbo
    May 2010
    Norsey
    i found with my vl that when i cranked it over the spring in the ingnition didnt return the key back far enough so the ingnition was still ingaged after it started. all i do is turn the key back once it starts to where it needs to be without turning the car off. sounds like you could have the same problem. if that makes sence to you try it and let us know how you go.
  1. Starter Motor/ Solenoid Problem?
    By 119LDP in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-01-2010, 07:55 PM
  2. vl starter motor problem
    By 1RUFVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-04-2009, 05:48 PM
  3. Possible Starter Motor problem
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2006, 11:31 PM
  4. Starter Motor Problem (VP)
    By kennedymr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2005, 07:21 AM
