Results 1 to 11 of 11
Thread: How do i clean my Pickup/Sump. Picture included.
    Deneo's Avatar
    Deneo is offline Lock your Daughters up
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Default How do i clean my Pickup/Sump. Picture included.
    hey guys.
    Finally got to the bottom of my oil problems i'm thinking.
    What's the best way to clean all this shit off the Pickup and All the shit out of the Sump?
    Cheers Deneo.
    vs commodore
    Oct 2009
    Tamworth NSW
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    change your oil every 5000km and this wont ever be an issue. its going to be a prick to clean.
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Only had the car for a few months, If i was the owner since it was released it wouldn't look like this lol.
    I got most of it off brushing lightly with a peice pf coathanger will go over it with diesel in the morning.
    There looks to be half a tiny gasket in the sump. Don't know if it's spun a bearing in the past and been repaired or what :S
    Thanks Deneo.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    ring an engine reco place and see if you can acid dip it. thats the best way to clean it.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    i cleaned my oil pick up and sump with degreaser and brush worked really good
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Should be able to unbolt the oil pickup if i remember correctly...?
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VS_Pete_1's Avatar
    VS_Pete_1 is online now Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Correct I bought a new one.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    yeah, Cleaned it with a few liters of diesel, Alot of shit in the pick up and sump! All back together now, Get the verdict when i get a sump plug washer tomorrow! only thing that's not in. What a mission it was though!!
    VS_Pete_1's Avatar
    Dec 2007
    This happened to my v6 it was getting 10,000k oil changers for 10yrs. with Magnatic shit oil.
    Another guy I know had the same trouble with Magnatic oil.
    After it was put back together I did a couple of 2500k oil changes and filters.
    I cut open the filters to have a look and there was little balls of crap inside not a lot.
    Now my oil is pretty clean at change time.
    Cost a bit to do but cheaper that a seized motor.
    Good luck with it mate.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    A mate I know had a air line connector brazed onto an old oil filter. Every time before he changed the oil, he would remove the old filter and replace it with his modified one, then connect the air set at 60PSI and give it a good blast. He reckoned the backflowed the pickup and stirred all the hot oil in the sump up...also blew all the old oil from the gallerys/lines. The then drained the oil and primed the new filter with fresh oil before filling the sump and starting the car. More than one way to skin a cat.
  1. Oil pickup touching sump?
    By maldotcom2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2010, 02:57 PM
  2. LS1 sump, deflector, oil pickup, dipstick
    By maddog in forum Parts And Other Items For Sale
    Last Post: 20-09-2006, 12:22 PM
  3. WTB (SA) VR Calais Wheels..(i think) picture included
    By JSTPOZN in forum Swap / Wanted to Buy / Trade
    Last Post: 09-06-2006, 10:13 AM
  4. Dash with tacho included
    By Ute 94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2005, 05:07 PM
  5. The eaisiest way to clean your oil pickup
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-05-2005, 11:24 PM
