Hey guys,
My Rpm gauge bounces up and down whilst idleing,driving,reversing, Anything pretty much
Any ideas as to what it could be?
Ive read on here quite a few times that some people have had this happen on the 5.0 engines just before the ignition module has died.It could be a sign that your ignition module is on its way out.It could also be a bad/broken solder joint or track on the dash's PCB.
The car also jerks when the rpm gauge is bouncing up and down
Thanks for the quick replies, I have a done a little research and may be looking towards fitting a new ignition module, Could this be the problem?
Yep i have ordered one, It will be here by today , will let you know how it goes![]()
Put the new Ignition module in, Rpm gauge is fine and car runs alot smoother,
Thanks for the help![]()
