Results 1 to 4 of 4
Thread: 97 Calais: Auto Gear Shift bulb/light
    97 calais vs 3.6
    Jun 2010
    Default 97 Calais: Auto Gear Shift bulb/light
    No light showing in the auto gear select consul; makes it hard @ night for checking which gear you're in. Can anyone help? Thanks
    VS V6exec
    May 2010
    NSW sydney
    pull your ashtray out, then use abit of force to lift the peice around the gear shifter, it pulls straight up, then grab the bits of plastic around the gearshifter and pull them away( has P, D,R,1,2,3 on it), then ull be able to get to the bulb to disconnect it
    PoisonBerryVS is offline Eat Me
    VS wagon
    Sep 2011
    what type of bulb is it? i think mine is dead?
    i got to it today but it cant come off, but it have a brow/white wire and for memory i think a black one too, any help?
    There is no such thing as death, life is only a dream, and we are the imagination of ourselves.
    VS Berlina
    Mar 2011
    Woodford QLD
    The bulb is a T10 wedge, you can buy them at SCA or anywhere else that sells globes. Probably even your local servo. It will come out, its a tight fit. It just pushes in and out, do NOT twist it. If you cant grip it, grab a bit of fine sandpaper and try to grip it with that and just pull.
    The biggest risk is breaking the bulb off and leaving the base still inside the socket, but if you do you can usually dig that out with a precision screwdriver or something fairly easily.
  1. 2005 VZ - How to change the light bulb when the auto trans shifter.
    By VZ05LUM in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-07-2009, 07:17 PM
  2. gear selector light or bulb stuffed?
    By clazzza commy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2009, 06:50 PM
  3. Gear Shift On An Auto,
    By Terence in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2009, 05:30 AM
  4. VX Calais Series 2 II Auto Gear Shift Surround in Marble - SA
    By Caprice5L in forum Parts And Other Items For Sale
    Last Post: 06-10-2008, 05:11 PM
  5. VY Calais Fog Light bulb change
    By DD Calias in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-04-2008, 08:33 PM
