Results 1 to 6 of 6
Thread: Rim size
    Vs Equipe
    Oct 2006
    Default Rim size
    hey all just wondering would original VE GTS rims fit a vs commodore that has been lowered with superlows in the front and ultra lows in the back , mind you the original VE GTS rear wheel is 8.5" I beleive any help would be much appreciated cheers all
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    No, the hub in the VE is a different size therefore they will not fit pre VE cars. You can get the wheels machined to fit pre VE cars, although I do not know much about this. Adversely you can buy VE GTS replicas that are made to suit pre VE.
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Yeah, if you get the hubs machined out, (I think 5 mm - 2.5mm each side) then they'l fit straight on. (Somebody correct me if I'm wrong?!)
    8 1/2" shouldn't be a problem, although you might not be able to run a 245 tyre on it with out rolling the rear guards, not too sure though, might just fit.
    VS III 5spd Ute
    Apr 2010
    Lake Macquarie
    Quote Originally Posted by Zeussy View Post
    I think that's correct; VS hub centre's are 68mm i'm pretty sure VE goes to 73mm??
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    smokyj you have it the wrong way around, the VN-VZ wheel hub hole is 70mm (not to be confused with the VT-VZ front brake disc hole 71.5mm) and the VE has a hole with a lip that is 65-68mm and it is this lip they machine out to fit them to earlier commies.
    Also thet rear VE GTS wheel is 9.5" wide, not 8.5" and the front wheel is 8" wide.
    The newer VE2 GTS runs 8.5" front wheel now but all the other HSV VE2's still run the 8" on the front all still with 9.5" rears.
    If you wanted 8.5" wheels you would have to buy 2 pairs of front VE2 GTS wheels.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VY Ex-cop
    Mar 2006
    keep in mind that any non standard non holden approved wheels for any model commodore can adversely affect ABS performance.
  1. What size box
    By mad055 in forum Car Audio
    Last Post: 26-07-2009, 11:31 AM
  2. what size cam
    By mr LS1350 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2008, 10:46 PM
  3. What size box for 15
    By Bonza3 in forum Car Audio
    Last Post: 17-01-2008, 10:15 PM
  4. Sub Box Size
    By Silver Phoenix in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2006, 11:37 AM
  5. What size amp for 6x9 and what size amp for subs
    By Infanti in forum Car Audio
    Last Post: 12-10-2006, 07:28 PM
